Paint recommendation for a daily user - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-04-2019, 07:35 PM Thread Starter
Thanks (Given): 8
I needed to disassemble my snowblower to fix a seized drive cable and as I dug deeper into the machine I encountered a few more issues. The result is that I have the chute and housing off as well as the impeller and augers. I know it is late in the year but I cannot help thinking that I should put a coat of paint on the rusty/bare parts.
This won't be a full restoration and sandblasting isn't an option. I've used a wire brush and flap disk in my grinder to clean up some the rust. It is a 20yr old honda; there is pitting and my rust cleanup isn't perfect. The previous owner damaged the bottom of the housing (typical shoeless Honda) and I'll likely repair/weld it next summer. Nevertheless, I'd like a paint that will hold up to typical use. Any recommendations?
r1web is online now
post #2 of 12 Old 12-04-2019, 08:54 PM
I used Tremclad gloss black, oil based paint on the impeller and gearbox. It held up very well last year. I like their water based version too - very fast dry and no odour!! Not sure how durable it is..
I rebuilt the drive assembly on another machine this year. I wire brushed and repainted the frame using Dulux Metal Clad paint. I bought it from Betonel - with a CAA discount.
They colour matched a piece of it - reddish orange. Great match. I don't have a good place to paint so it takes longer to dry in a cold garage. Spray paint would be smoother too.
Also two coats would have been better but I figure I can touch it up in the summer (yea right!). Summer should be spent in the Kawarthas (Kirkfield) playing with boats!
Anyway, my 2 cents.
The ultimate might be POR-15 paint - just more prep work and cost involved.
Allan
Allan is offline
post #3 of 12 Old 12-05-2019, 07:06 AM
CarlB's Avatar
Thanks (Received): 35
Likes (Received): 81
I used rustoleum on my cub cadet when i restored it about 9 years ago and it has held up very well no rust at all on the machine.
CarlB is offline
post #4 of 12 Old 12-05-2019, 07:28 AM
oneacer's Avatar
Thanks (Received): 148
Likes (Received): 539
I use a primer and then recently the Farm Equipment Husqvarna Orange Gloss. Went on and came out great.
oneacer is online now
post #5 of 12 Old 12-05-2019, 07:39 AM
Likes (Received): 18
I've used "hammered" finish from Rustoleum for inside the chute and it seemed to be doing well, regular Rustoleum on anything else
firedudetl1 is offline
post #6 of 12 Old 12-05-2019, 08:26 AM
Likes (Received): 27
Also... You can achieve some interesting effects by warming the part prior to paint. Low 100's paint adheres better. At high temps the paint can almost instantly solidify, turning into a very hard surface with a textured appearance.
Years ago I sprayed rattle-can semi-gloss Rustoleum onto a metal part that I heated with a torch. The result was a crinkled finish that was tough & durable.
That was decades ago, the painted part is still holding up.
Ariens 1124DLE
(*sold:Ariens ST27LE)
(*sold: John Deere TRS21)
Toro 821
melson is offline
Likes Waylon liked this post
post #7 of 12 Old 12-05-2019, 12:29 PM
toofastforyou's Avatar
Thanks (Received): 7
Likes (Received): 61
Nothing beats powdercoating but it's more expensive but worth it if you plan to keep your machine for a long time… … but if you'd rather paint it, then first have it sandblasted, primered and then painted. The original paint on most snowblowers doesn't have any metal preparation or primer. That's why they all rust after a few years…
Claude.
2004 MURRAY BRUTE 10HP 29"
toofastforyou is offline
post #8 of 12 Old 12-05-2019, 02:39 PM
Thanks (Received): 15
Likes (Received): 19
I use a rust conversion coat before a colored top coat in cases where I haven't gotten all the rust off.
So far so good but I don't yet know how things hold up in the long term.
cpchriste is online now
post #9 of 12 Old 12-05-2019, 03:02 PM
vinnycom's Avatar
Thanks (Given): 59
Thanks (Received): 71
Likes (Given): 58
Likes (Received): 183
in the cold apply a hairdryer or heat gun(on low) to aid in drying
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #10 of 12 Old 12-06-2019, 08:12 PM Thread Starter
Thanks (Given): 8
Thanks everyone. I've turned on the heater to my garage and it should be warm enough to paint inside tomorrow. More snow this morning and I needed to shovel it. I really need to get this back together.
r1web is online now
