Starter intermittency - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-05-2019, 12:09 PM Thread Starter
I started repairing small engines this year and by this I mean I started replacing carbs on old machines to make them work... on a couple machines I have the starters seem to work a couple times, then nothing (starter gear won't even try to spin). I've taken them apart, cleaned all the electrical components, put them back together and same thing, it will work once or twice and then nothing. What is typically the culprit here? TIA
aedude006 is offline
post #2 of 5 Old 12-05-2019, 12:24 PM
Thanks (Received): 151
Likes (Received): 546
I would assume the winding itself ….
oneacer is online now
post #3 of 5 Old 12-05-2019, 12:36 PM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
There are multiple windings on the rotor which are connected to the commutator. The brushes run on the commutator. One or more of the windings on the rotor are open. When the motor stops with the brushes on an open winding the motor won't run. Spin the rotor so that a winding that is not open is in the circuit and the motor will start and run, but the motor will not be able to make full power with open rotor windings.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #4 of 5 Old 12-05-2019, 01:43 PM
Thanks (Given): 59
Thanks (Received): 72
Likes (Given): 58
Likes (Received): 183
multimeter would help to see if windings are shot, but rare for them to die as theyre not stressed out that much, the gears get stripped out as the main failure cause of loose mounting bolts.
i havent even used mine yet as it starts with one pull, bought it used and neglected a few years ago and the machine is over 30yrs old
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #5 of 5 Old 12-05-2019, 02:37 PM
I have starters on 4 of my 7 blowers, but never use them either.... mine start with pull cord just fine.
