#1 reason for non starting - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-07-2019, 10:22 AM Thread Starter
Thanks (Given): 95
Thanks (Received): 189
Likes (Given): 72
Likes (Received): 434
#1 reason for non starting is fuel
#1 reason is bad gas
#2 reason is water in the gas
#3 reason is old gas
#4 is holes, ports, in the carb are clogged or partially clogged
#5 fuel is not getting to the intake valve, fuel is either not getting to the fuel bowl which means line, petcock, or fuel inlet valve is sticking; or not being pulled up through the main jet located in the middle of the carb underneath inside the fuel bowl.
When I have a starting issue, I loosen the nut on the fuel bowl and drain a little gas in a clear soda bottle. If there is water in the gas, it will sink to the bottom. Then look at the bottle, you will see the separation between water and gas! You can also see if the gas is not clear, there should be virtually no color to it, then drain everything! Everything! Your gas can TOO, in to a clear soda bottle. Completely! Until the can is totally dry. You brought the problem to me. I'm going to solve it, my way. I don't believe you.
Other than very very seldom reasons for non starting such as seizing engine, very low compression, valve lash, valves not sealing
Only two reasons, ignition or fuel
Spray starting fuel in the carb or in the spark plug hole, if it starts, generally, it's not ignition, it's a gasoline problem.
Post Thanks / Like - 1 Thanks, 5 Likes, 0 Dislikes
post #2 of 12 Old 12-07-2019, 10:23 AM
oneacer's Avatar
Thanks (Received): 122
Likes (Received): 427
Ditto .
oneacer is online now
post #3 of 12 Old 12-07-2019, 10:34 AM
Likes (Received): 722
Can't add anything to that....
cranman is online now
post #4 of 12 Old 12-07-2019, 11:36 AM
Thanks (Given): 63
Thanks (Received): 59
Likes (Given): 115
Likes (Received): 79
Pretty complete!
I just like to shut off the gas valve and dropping the bowl. I can then get a better idea if it is just bad gas or a build up of crap in the carb. If the bowl has a bunch of sediment or the white powdery corrosion it is more complicated solution than just using fresh gas.
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #5 of 12 Old 12-07-2019, 12:49 PM
Thanks (Given): 8
Likes (Given): 23
I agree mostly but for me in 90% of the cases I will remove old fuel, change filter, add new fuel from new source, run the new fuel through the bowl to purge all remnants of gas and the bugger will still not work.
So, your top 3 reasons for me are not the culprit 90% of the time for me.
Now #4 and carb issues, that's where I find the issues.
Waylon is offline
post #6 of 12 Old 12-07-2019, 01:01 PM
orangputeh's Avatar
Thanks (Given): 717
Thanks (Received): 209
Likes (Given): 1339
Likes (Received): 1356
yup.
you can tell owners this ALL THE TIME but 99% will not listen.
will have the same problem the following year.......in that case I charge DOUBLE......then they ( may ) learn.
but doubt it.
"It Feels Like Beer O'Clock "
orangputeh is online now
Likes SayItAintSnow liked this post
post #7 of 12 Old 12-07-2019, 01:43 PM
SayItAintSnow's Avatar
Thanks (Received): 29
Likes (Given): 44
Likes (Received): 138
Originally Posted by orangputeh View Post
yup.
but doubt it.
Lol.....so true, my friend!
But then to every problem there is usually an "up side"......
If it weren't for folks like this, there wouldn't be so many free or nearly free snowblowers on Craigslist every Spring and Summer, for those of us that know how to restore them and make them useful to someone once again!
--- Clint Eastwood
SayItAintSnow is offline
post #8 of 12 Old 12-07-2019, 02:47 PM
penna stogey's Avatar
Thanks (Received): 17
Likes (Given): 107
Likes (Received): 39
Thank you!
2019 Ariens Compact 24...
penna stogey is online now
post #9 of 12 Old 12-07-2019, 03:23 PM
orangputeh's Avatar
Thanks (Given): 717
Likes (Given): 1339
it's the same people who used to get a new car once the ashtray was full........
post #10 of 12 Old 12-07-2019, 04:54 PM
Zavie's Avatar
Thanks (Received): 116
Likes (Given): 559
yup.
but doubt it.
And just what is the going rate in your area for this service. Prolly just $25-$35 bucks because it's easy to do right?
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
