Tecumseh 8 HP Over Reving all of Sudden - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 12-09-2019, 03:45 PM Thread Starter
Hello All
Tecumseh HMSK80 155487S
The Guy across the Street was snow blowing my driveway for me while I was away on a trip. All of a Sudden the engine started to Over Rev.
No warning did not touch anything just happen.
I can work on Small Engines so tried over the phone to help him - He removed the Carb cover and could not find anything that Looked Broken or Disconnected from the outside.
Or snow packing someplace.
Since we had 22" Snow fall and needed a snowblower we went and purchase a new one.
I came home yesterday and went to look at it. As soon as you start it with the Throttle in Full Run it over revs right away. If you lower the throttle to the bottom it seems to run normal idle and sits there running Ok. Have looked at Videos and Read posts - see a lot on over revving - most are from people changing Carbs and not installing linkage correctly or adjusted the Governor incorrectly. Can find nothing on this Happening all of Sudden.
What do you think can cause this to happen all of Sudden? Besides Governor Failing inside engine - if that did happen is there a way to check from outside.
Want to try and eliminate all springs and linkages before opening the engine to check governor inside. Did not see anything that looks wrong or broken.
Checked round spring on Throttle it is there and works. I seen one video on tighten that spring tighter but do not know how this can make Rev all of Sudden.
Was thinking to remove the engine oil and look at it to see if find any metal or plastic that may come from inside governor. I heard the gear is plastic and can break in pieces.
Any help would be appreciated
Thank you
Mike Smith is offline
post #2 of 12 Old 12-09-2019, 03:49 PM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Any chance you can shoot a photo or 3 of the throttle-carb-governor linkage and post?
I will say that if really truly nothing was done to the engine and the problem appeared out of nowhere, it's likely the governor broke inside the engine. Those plastic gears are getting pretty old! If it broke you might find pieces in the oil, but they alsod may be large enough that they can't fit through the drain hole.
Another possibility that comes to mind is the governor arm slipped on the little shaft that comes out of the engine. I think if you google or look around youtube there are some videos that show how to adjust that arm on the shaft.
Oh and specifically to the point of testing the governor, there's really no specific way to do that. It's more a process of elimination... if the linkage is installed and adjusted correctly, the governor pretty much has to be the problem.
ELaw is online now
post #3 of 12 Old 12-09-2019, 04:02 PM Thread Starter
As soon as can get pictures will post - not sure when he will be home so can get to it. I know how to adjust governor linkage will do that too before re-posting pictures.
Thanks for help
post #4 of 12 Old 12-09-2019, 05:13 PM Thread Starter
Talked with him and he said he was going into heavy snow so was loading the engine up when happen and revved up.
ID:	160667   Click image for larger version
ID:	160669   Click image for larger version
post #5 of 12 Old 12-09-2019, 05:18 PM
Zavie's Avatar
Thanks (Given): 71
Thanks (Received): 118
Likes (Given): 571
Likes (Received): 269
Donyboy73 video on over-revving Tecumseh:
2016 Ariens Professional 28
2017 Toro Power Clear 721R
2018 Simplicity Select 1024
Zavie is offline
post #6 of 12 Old 12-09-2019, 05:25 PM
1132le's Avatar
Thanks (Received): 99
Likes (Given): 68
Likes (Received): 223
Sounds like the gov took a dump
or the set screw holding it tight is loose
readjust gov it takes 5 min there are vids on you tube if you have never done it
the arm should be slightly towards carb when adjusted right with the throttle on full
there are 2 ways to adjust it make sure you understand it
if still revs,and the carb linkage isn't farked up
the gov took a dump
1132le is online now
post #7 of 12 Old 12-09-2019, 06:31 PM
Thanks (Given): 62
Thanks (Received): 70
Likes (Given): 263
Likes (Received): 164
Mike: in your 2nd pic, is there a spring hanging from the linkage assembly that is attached to the shroud?
Paul
paulm12 is online now
post #8 of 12 Old 12-09-2019, 06:37 PM
1132le's Avatar
Likes (Given): 68
Le
I see no spring you mean the throttle cable
post #9 of 12 Old 12-09-2019, 06:42 PM Thread Starter
This snowblower has a Throttle Control on the front panel between handle bars - it does not have a leveler with red knob to control speed
I think you see the wire and the cover ( looks like spring) that goes to the throttle.
Click on the picture you may see better - if not that I do not see what you see
post #10 of 12 Old 12-09-2019, 06:50 PM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
. . . Governor Failing inside engine - if that did happen is there a way to check from outside. . . .
here's how to get a clue of the condition of the internal governor (and how to reset gov arm)
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
