Ariens Remote Wheel Lock Repair - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-10-2019, 05:05 PM Thread Starter
Likes (Received): 7
I have a remote wheel lock Ariens that's been giving me some trouble and I found a very good solution. There's a guy on youtube who shows where to lube the sliding pawl/dog. BUT no one really gives you the low down on setting the adjustable cable length.
So here is what I found.
First of all get everything free and sliding.
I copied the you tube guy by pulling the spring that surrounds the axle away from the dog mechanism. Pulled it back with a couple of 90 degree picks and then clamped it out of the way with a vise grips.
I sprayed down the rusty stuff with some penetrating fluid. Worked the stationary left side of the dog device by turning it repeatedly. I ratcheted it past the click stop a number of times with a flat bladed screwdriver until I was happy that it was moving well. Then I used the same screwdriver as a lever and a punch to move the sliding section back and forth until it freed up. I made sure to slide it fully right and fully left to it's stops until it moved well.
I greased the splines between the dogs.
Next I over adjusted it with too little slack, ie. too tight. What that did was allow it to only work once, because the ratcheting device could not get to the next click.
Once I figured that out I took out some tension until the trigger allowed the ratchet to click to the next dog each time it was released and now it works the best I have experienced.
The key thing was getting the cable length just right. Once there is just about zero slack it works beautifully.
3repete is offline
Likes rod330 liked this post
post #2 of 3 Old 12-10-2019, 07:06 PM
Thanks (Given): 80
Thanks (Received): 47
Likes (Given): 276
Likes (Received): 156
Great post....that mechanism is notorious for hanging up if it's not lubricated on a regular basis and the cable slack removed. Perhaps you can post the YouTube link. There's also another forum discussion with some great info posted by CO Snow (post #17) and my own post #18.
https://www.snowblowerforum.com/foru...mal%C2%85.html
Here's a snapshot from the Owner's Manual to describe the cable tension adjustment on an Ariens 921 I just refurbished.
Name:	Screen Shot 2019-12-09 at 9.28.45 PM.jpg
rod330 is online now
post #3 of 3 Old 12-11-2019, 08:28 PM Thread Starter
Likes (Received): 7
Thanks for the kind words.
I think I remember having an instruction page like that when i did the cable 2 years ago. But it's nowhere to be found in the manual for my 926102 which is a 2005 11528 with a 318cc Tecumseh engine.
So I thought I'd post my experience when I didn't find a post on how it's done.
Apparently I don't search well.
On the more practical side. We had a dusting today in southern NH so I had to do a quick scrape when I got home from work. It's a joy to use when everything works well. The axle lock clicks nicely now so I'm happy.
I almost started to get a different axle system altogether, glad I stayed with what I have. It's good that the wheels are locked when I go over the depressions in my driveway, keeps my machine nice and straight.
Plus I can keep the unspent money for more important things like food, beer, tools, boat parts...the normal things I wish for!
3repete is offline
