New engine, New carb, Not sucking gas in to engine - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-13-2019, 03:32 PM Thread Starter
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
Short - Gas is in the bowl but not being drawn up in to the engine.
August 2019, I was called to repair a non starting snowblower, Craftsman, Chinese engine. He told me he bought it brand new in Dec? 2018 January 2019? (I don't think so)(He told me today the warranty expired July 2019) The problem was non-starting. I drained the gas, very very old looking with water in it. I drained the gas can which he filled the snowblower months (only months supposedly) before, disgusting. With fresh gas it didn't start with the electric start. I sprayed starting fluid in the carb through the throttle lever slot and it started but ran crappy as if the carb was dirty. I let it run to warm up. Tried again. It wouldn't start. I sprayed starting fluid again bit I did not direct the spray well, it backfired or popped, the excess starting fluid around the carb caught fire, flames. I sprayed it with a hose to put the flames out. Upon removal of the carb housing and carb, the fire caused the choke plastic and choke thing with the hole in it for the linkage to melt so I felt forced to buy a new carb at my own expense. I made a mistake by not putting gas in it and starting it. I did not want gas to sit for 5+ months. He called me this week because he could not get it to start. I drained the gas and it was dark golden in color. I put fresh gas in. It would not start. It has good spark. Putting gas in the spark plug hole it starts and runs but stops when that gas is consumed. Gas is freely flowing in to the carb bowl and out from the float inlet valve. Gas is not being drawn up in to the engine intake valve. I did not have time but I was going to stand the blower up, remove the carb housing and bowl, then spray carb cleaner in to the main jet. If the main jet is removable, I will remove it. After this, what is there? Remove the carb, disassemble, and spray in to every hole? Replace the carb? It was $80! On the internet! New snowblower, New engine, assume good compression, assume new valves, assume valves are good.
post #2 of 9 Old 12-13-2019, 03:42 PM
Thanks (Given): 59
Thanks (Received): 72
Likes (Given): 58
Likes (Received): 183
if its not drawn up then compression is bad, check compression.
or float set too low, mixture set too lean, choke not closed
dirty carb
MY VIDS ON FIXIN HER UP
vinnycom is offline
post #3 of 9 Old 12-13-2019, 03:50 PM
Thanks (Given): 79
Thanks (Received): 83
Likes (Given): 330
Likes (Received): 362
+2 for compression
No squishy, no sucky either
1989 John Deere 1032
tdipaul is offline
post #4 of 9 Old 12-13-2019, 03:54 PM
Thanks (Received): 212
Likes (Received): 767
Those carbs on E-bay are less then $20 ...I've bought a few.....
cranman is offline
post #5 of 9 Old 12-13-2019, 04:25 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
If the gas was green, it went bad, I'd clean the carb or replace and check compression, as others have said. Sounds like the owner neglects their equipment. I wouldn't go back after this.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #6 of 9 Old 12-13-2019, 04:25 PM Thread Starter
Thanks (Given): 97
Likes (Given): 76
The $80 was on eBay and Amazon. I only had the carb # from Craftsman to do a search.
post #7 of 9 Old 12-13-2019, 04:46 PM
funny..I've done a couple of Craftsmens last few years with the chondra engines and had to replaces carbs...less then $20 for the ones I did...
cranman is offline
post #8 of 9 Old 12-14-2019, 01:54 AM
Likes (Given): 17
Likes (Received): 33
Pull the spark plug and do the finger test on the compression/intake strokes. You may have a stuck valve.
Yamaha tracked 624
Honda tracked 928
Honda Foreman 60Ē plow
Nanook12 is offline
Thanks JLawrence08648 thanked for this post
post #9 of 9 Old 12-14-2019, 04:34 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
chances are since the main jet is at the lowest point in the carb that it is again plugged from dirt in the fuel . the machine runs on fuel being directed to the engine, so it's not drawing up to . clean that carb it's new so hopefully you can reuse the gaskets
87powershiftx2 is offline
