Auger continues to spin - Snowblower Forum : Snow Blower Forums
post #1 of 9 Old 12-15-2019, 12:37 PM Thread Starter
Hello. I have a craftsman 9 hp tecumsah (sp) 28 inch wide blower that the auger continues to spin even with the handle not held down. I can spin the ejector freely while not pressed but when the motor is running, so is the auger. The pully seems to be adjusted right as the belt is pretty loose until the handle is pressed down. The belt on it has grooves and is not smooth like the belts that replaced it. Could that have anything to do with it?
Thank you in advance for your time.
Shwthomas1975 is offline
post #2 of 9 Old 12-15-2019, 01:07 PM
Thanks (Received): 152
Likes (Received): 549
Some photos would help, as well as what type of blower?
oneacer is online now
post #3 of 9 Old 12-15-2019, 01:41 PM
Thanks (Given): 72
Thanks (Received): 123
Likes (Given): 120
Likes (Received): 157
Probably check for the belt guard not adjusted within an 1/8" on tension side of belt, See first pic with the right side of belt guard being the critical dimension. Also that the belt has a 1/2" of free play on tension side as shown in attached diagram. The other aspect is the brake pad attached to the clutch apply lever abutting the impeller pulley being worn out.
Depending on make and model these features may not apply.
Good luck.
Name:	Auger belts idler wheel 2.jpg
ID:	160985   Click image for larger version
Name:	Auger belt tension diagram.jpg
Town is online now
post #4 of 9 Old 12-15-2019, 03:01 PM Thread Starter
I took a couple. But can’t figure out how to post lol. I’ll keep looking.
post #5 of 9 Old 12-15-2019, 03:08 PM
I just drag and drop Ö.
post #6 of 9 Old 12-15-2019, 08:11 PM Thread Starter
Think I got it 🙂
ID:	161039   Click image for larger version
post #7 of 9 Old 12-15-2019, 08:30 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
its possible the return spring on the tensioner/brake is broke or gone. i know the one on my snowblower is gone all together and have fixed a few machines where they were rusted and broken.
yardworks 31AH6WKF515
crazzywolfie is online now
post #8 of 9 Old 12-15-2019, 11:15 PM Thread Starter
I just watched a YouTube video on the brake spring. That makes perfect sense. The guy has to pull the whole thing apart to get top it tho. How bad is it to leave as is? I know it’sa safety thing I suppose, but beyond that are there any ill affects?
Thanks again.
post #9 of 9 Old 12-15-2019, 11:26 PM
Likes (Given): 76
hard to say exactly without a model number but most of the time they are at the bottom. pull the bottom pan and should be connected to the arm near the impeller brake. you can see the one on my machine in this pic
