Compatibility: Tecumseh HMSK80 vs LH358SA camshaft - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 12-15-2019, 05:38 PM Thread Starter
Question Compatibility: Tecumseh HMSK80 vs LH358SA camshaft
Old engine is a Tecumseh HMSK80 8HP with dual-shaft output.
Replacement engine is a Tecumseh LH358SA 10.5 HP with single-shaft output.
I am wanting to convert the LH358SA to dual-shaft output.
Are the camshafts compatible between these two engines? Part numbers are different (36655 vs 35375) but I can't determine if this is just for the provision of the second output shaft or if the cam & timing is different.
BhimaHyperion is offline
post #2 of 3 Old 12-15-2019, 06:04 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
You should be able to swap the cam and side Cover with no ill Results.
The Ignore List Takes out the Trash
Jackmels is offline
Thanks BhimaHyperion thanked for this post
post #3 of 3 Old 02-06-2020, 08:20 AM Thread Starter
Coming back around to this post to thank Jackmels. I was able to change the camshaft from the HMSK80 8HP into the LH358SA and get a running engine. (First pull!) Along with swapping the sump cover, this gave me the dual-shaft setup that I needed.
Likes Jackmels, 87powershiftx2 liked this post
