Replacement friction disk - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 12-17-2019, 10:33 AM Thread Starter
Thanks (Given): 67
Thanks (Received): 60
Likes (Given): 115
Likes (Received): 81
I just purchased an after market replacement disk for an MTD machine.
It was a Stens 240-991.
The friction surface appears to have a thin rib protruding rib around the circumference on the center.. It is like a relatively thick uniform parting line from the molding process. It seems uniform 360 degrees around. Unlike typical mold flash that is irregular.
Is this common as I don't buy a lot of these. Never seen it before and wondering if it wears in fast and doesn't create any issues.
It is a PITA to return and would prefer to use it if it will work fine.
I have had very good quality from Stens products in the past. Just wondering. Any thoughts?
Current machines
Ariens 926LE
Toro-8-2-4 is offline
post #2 of 2 Old 12-17-2019, 10:40 AM
Thanks (Received): 152
Likes (Received): 549
I have seen the slight manufacturing mark (ring) you are referring to before. Not an issue at all … that will be just fine and the disc operation will perform as normal. It will press in up against the drive plate with no issues. I have had this on some in the past.
oneacer is online now
Thanks Toro-8-2-4 thanked for this post
