Green Wiring diagram or video for an old MTD Snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 12-17-2019, 03:09 PM Thread Starter
I have a broken green wire coming out of the engine area and I don't know where it connects. I think that it connects to the throttle. Under the carburetor cover, there is also another green wire for the key that I need to insert before electrically or manually starting the engine. The MTD model that I have is 31AE665G552. I downloaded the manual from MTD Canada and I wasn't able to find out how to reconnect them. Please help! Cheers
RFMTD is offline
post #2 of 5 Old 12-17-2019, 04:15 PM
Thanks (Received): 80
Likes (Given): 75
Likes (Received): 276
does the key switch on the housing still work for killing the engine? that switch usually plugs into the bottom of the throttle control thing. seen many with loose or broken connections.
yardworks 31AH6WKF515
crazzywolfie is online now
post #3 of 5 Old 12-17-2019, 04:33 PM
Thanks (Given): 201
Thanks (Received): 126
Likes (Given): 413
Likes (Received): 266
Many times a GREEN wire is an "Earth Ground" wire, if it is all green and no tracer color added, meaning it is just a ground wire. That was an electrical code standard for that color. Many times black was "switched on"
or "key on" power. Red with a white trace was also "key on" power.
ST1100A is offline
post #4 of 5 Old 12-17-2019, 05:27 PM Thread Starter
Thank you for helping!
Yes, the key switch is working fine. I can`t find either a video or a simple diagram that would show me where the 2 green wires connect. one that seems connecting from the engine and the other one starts inside the carburetor by the switch area. Are both wire joined at the throttle area?
RFMTD is offline
post #5 of 5 Old 12-17-2019, 06:23 PM
Thanks (Received): 173
Likes (Given): 415
Likes (Received): 664
hear ya go....kinda !
24 " 1967? Ariens Sno thro
28 " Ariens Sno Tek
Toro CCR ss
