Help with Governor Linkage - Tecumseh Over Revving - Snowblower Forum : Snow Blower Forums
post #1 of 14 Old 12-17-2019, 08:01 PM Thread Starter
rod330's Avatar
Thanks (Given): 78
Thanks (Received): 44
Likes (Given): 265
Likes (Received): 132
I'm refurbishing an Ariens ST7524E (932041) with a Tecumseh OH195SP engine. It starts fine with a new carb and runs well at idle (around 1800- 1900 RPM). However, it over revs at full throttle and I immediately shut if off when it jumped to 4400 RPM. I worked on a similar machine a couple of years ago but didn't have this issue.
I don't see any way to adjust the governor arm and there isn't an adjustment screw at the throttle linkage attached to the engine shroud...at least not that I can see. At first I thought I could adjust the arm with screw at the bottom but it appears that's just how the arm is attached to the oblong engine governor shaft.
There really isn't much throttle travel on this model....it's more like off / idle / and full throttle. The yellow snot in the 4th photo is Fluid Film I used to lubricate the throttle mechanism. Looking at the parts diagram I see there's a spring (#19A) but I'm not finding it on my unit...not sure it's intended for the governor linkage though. Any suggestions would be appreciated.
ID:	161151   Click image for larger version
ID:	161153   Click image for larger version
ID:	161155   Click image for larger version
ID:	161157   Click image for larger version
rod330 is online now
post #2 of 14 Old 12-17-2019, 08:52 PM Thread Starter
rod330's Avatar
Thanks (Given): 78
Likes (Given): 265
Well, now that I expand the first and second photos, I'm thinking the governor arm can indeed be adjusted at the shaft near the screw. The end of the engine governor shaft is oblong (maybe to hold while you move the arm?) but the shaft itself appears to be round....hmmm....
post #3 of 14 Old 12-17-2019, 09:09 PM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
DO NOT adjust the governor arm at the shaft near the screw.
Note the spring that goes from the governor arm to the tab that hangs down from the throttle control, the spring wire goes through the hole in the tab and then forms a U. The tab that hangs down is the high speed adjustment, bend the tab to adjust the maximum speed.
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
Thanks rod330 thanked for this post
Likes rod330 liked this post
post #4 of 14 Old 12-17-2019, 09:41 PM Thread Starter
rod330's Avatar
Thanks (Given): 78
Likes (Given): 265
Excellent - the tab at the RED arrow, correct?
Thanks Toromike!
post #5 of 14 Old 12-17-2019, 09:56 PM
Likes (Given): 45
Correct, the red arrow tab is the governed high speed adjustment. I think this engine has a governed idle speed as well, the green arrow tab would be the governed idle speed adjustment.
FYI, do not move the governor arm at the shaft near the screw unless you are disassembling the governor, or resetting the governor adjustment. There is a specific procedure to reset the governor arm, but it rarely needs to be done, mostly when someone has messed with it.
1997 Toro 724
post #6 of 14 Old 12-17-2019, 10:21 PM Thread Starter
rod330's Avatar
Thanks (Given): 78
Likes (Given): 265
As it turns out, someone messed with it (me) before reading your first post. Dang it!! Is there a source document I can reference instead of continuing to pester you?
post #7 of 14 Old 12-17-2019, 10:49 PM
Likes (Given): 45
Don't worry about it, we've all done it at one time or another.
All these governors work on the same principle. These videos explain how to do it, they may not be exactly like your machine but the principle is the same. If you need more I can come up with something else.
1997 Toro 724
post #8 of 14 Old 12-18-2019, 12:17 PM
Likes (Given): 45
rod330, here are some Tecumseh manuals that will give you further information on governors. They also contain lots of other information.
see page 26 figure 14 for a diagram of your throttle speed control
see page 25 at the bottom for how to set idle and high speeds
http://www.barrettsmallengine.com/ma...alvemanual.pdf
see page 27 for how to reset the governor arm,
I think the videos explain it better
Also, lots of other tecumseh manuals are available here
Tecumseh Service Manuals
Good luck
1997 Toro 724
post #9 of 14 Old 12-18-2019, 09:06 PM Thread Starter
rod330's Avatar
Thanks (Given): 78
Likes (Given): 265
Thanks again, Toromike.
Yes, the 2nd Teryl video is especially good and I hadn't seen that one.
Those tech manuals are quite good; I glanced at two of them before posting but wasn't as diligent as you at sifting through the many varieties. I'll be more patient next time
Anyway, I'm going to take a crack at it Friday, weather permitting. It should be easy to get full throttle RPM to 3600 bending the tab.
post #10 of 14 Old 12-18-2019, 09:55 PM
orangputeh's Avatar
Thanks (Given): 756
Thanks (Received): 232
Likes (Given): 1559
Likes (Received): 1613
just wondering if throttle plate moves freely? had this problem on several Honda hs724's and the throttle plate was stuck open. a little oil and they worked fine and had no more problems.
however in these cases it over revved from the beginning.
"It Feels Like Beer O'Clock "
orangputeh is online now
