when did Tacumseh swap over to electronic ignition? - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 12-22-2019, 05:12 PM Thread Starter
Thanks (Received): 212
Likes (Received): 767
greeting friends....in a nutshell, when did Tecumseh start using electronic ignitiion? were there any black engines after 1980 with points still? Is there an easy way to tell without taking the shroud off?
cranman is offline
post #2 of 4 Old 12-22-2019, 06:04 PM
scrappy's Avatar
Thanks (Received): 41
Likes (Received): 98
Good question! I'm not sure of an exact date, but sometime after 1983 is what I can find. Possibly not until 1987.
Look at the ID tag and look up parts diagram to see if in fact it has points.
The CDI/ coil unit is mounted on the outside of the flywheel. Maybe sneak a peak under the cooling shroud.
scrappy is offline
Thanks cranman thanked for this post
post #3 of 4 Old 12-22-2019, 06:51 PM
Jackmels's Avatar
Thanks (Received): 194
Likes (Received): 814
The Mufflers are a dead giveaway. Anything that does not have the "Square Box" Type muffler is points. Seen Them Black as well.
ID:	161387   Click image for larger version
The Ignore List Takes out the Trash
Jackmels is offline
post #4 of 4 Old 12-22-2019, 07:05 PM Thread Starter
Thanks Jack...I knew you would have an answer that even I could understand! I am getting so I hate points! The two I had questions about are square box mufflers...so I guess I'm safe!
cranman is offline
