Question about this float bowl and whats attached to my chute? - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 12-27-2019, 12:10 PM Thread Starter
Likes (Received): 10
So maybe a stupid question but this bottom screw seems to always have a drip of gas on it. Its not leaking but it just always has a drip. Is that normal operation? Should I tighten the bolts or? Is the bottom bolt the one to drain the carb I am guessing? What is the other one? last but not least lol... What are those forks inside the chute of my snowblower? My previous one didn't have that
ID:	161647   Click image for larger version
dubzino is offline
post #2 of 20 Old 12-27-2019, 12:18 PM
Thanks (Received): 150
Likes (Received): 543
No, having gas drips is not normal on the bottom of the carburetor. Snug up some nuts, or replace some washer/gaskets.
Many manufacturers are placing obstructions in the chute areas to try and avoid those individuals that are not to smart, from sticking there hands in there.
oneacer is online now
post #3 of 20 Old 12-27-2019, 12:25 PM Thread Starter
But from what I understand the bottom bolt is meant to release fuel if you over prime or something?
dubzino is offline
post #4 of 20 Old 12-27-2019, 01:50 PM
Thanks (Received): 212
Likes (Received): 767
The bottom bolt is to tighten the bowl gasket ...the one on the side is to drain the bowl
cranman is offline
Likes 87powershiftx2, Waylon liked this post
post #5 of 20 Old 12-27-2019, 04:13 PM
Likes (Received): 16
The bottom center bolt does hold on the float bowl, gasket and also most likely is the main high speed jet.
cdestuck is offline
post #6 of 20 Old 12-27-2019, 09:32 PM
Thanks (Received): 26
Likes (Given): 120
Likes (Received): 98
From the photo,I can't tell what brand of engine it is,but the carb looks like a,or copy of,a common Honda BE-type.If it is,the main jet is a separate piece from the bowl nut.
Mike C. is offline
post #7 of 20 Old 12-27-2019, 09:41 PM
Likes (Given): 17
Likes (Received): 31
Replace the seal or use a fuel sealant on the seal. I use fuel lube, sparingly. You should always have a carb gasket kit on hand, has all the seals in it.
Yamaha tracked 624
Honda tracked 928
Honda Foreman 60” plow
Nanook12 is online now
post #8 of 20 Old 12-27-2019, 10:22 PM Thread Starter
Shouldnt I just try tightening the drain bolt first before I go changing seals?
dubzino is offline
post #9 of 20 Old 12-27-2019, 10:39 PM
Thanks (Received): 11
Likes (Given): 34
Likes (Received): 24
Yes! Good luck
Ariens 1969 10,000 Series-- Tractor 10965 serial # 005841 with 10995 serial # 023507 Sno-Thro
Ariensboy is online now
post #10 of 20 Old 12-28-2019, 12:18 PM Thread Starter
I thought when you prime to much the access comes out from around the drain bolt no?
dubzino is offline
