1979 Ariens 7hp- cocked pulley... - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 12-27-2019, 07:24 PM Thread Starter
Likes (Received): 11
Model 924038
I have a drive pulley that's not perpendicular to the drive belt.
I tore it apart and discovered the pulley shaft 'egged out' the mount and that's why it's not inline. Wobbles when moved.
Any remedies? Brass sleeve? Oversize the hole in the bracket and tack in a sleeve? Cut bracket out and somehow bolt in a new one?
My buzz box welding is less than steller, so I would prefer a remedy that doesn't involve me using it on such a small bracket.
Thanks.
ID:	161687   Click image for larger version
ID:	161689   Click image for larger version
TiminOhio is offline
post #2 of 11 Old 12-27-2019, 07:59 PM
Thanks (Received): 149
Likes (Received): 543
Without doing some welding, you could always connect a spring from the idler bracket to one of the bolts on the handlebar or engine mount, or even drill a 1/8 inch hole somewhere in the housing for the other end of the spring, so there is tension to draw the idler pulley straight in-line when engaged with the drive pulley.
I had this happen on one, I that I took apart, and welded it up, as well as another washer … … These units are built so well, that going for 50+ years causes some parts to just plain wear out …
BTW, I would also put some nice X-Trac and that machine as well, instead of the turf tires. ….. big difference.
oneacer is online now
post #3 of 11 Old 12-27-2019, 08:31 PM
Thanks (Received): 195
Likes (Received): 816
I would Try Inserting a Bushing.
"Thank You Mr. Know it All!"
Jackmels is offline
post #4 of 11 Old 12-27-2019, 09:04 PM Thread Starter
So, I should get a bushing to fit the shaft and try to fit it in the bracket? Maybe put some jb weld between the bracket and the lip of the bushing?
That sounds too easy.. I hope that's the case.. cause I'm sitting here pondering cutting out the original bracket and bolting in a small homemade tube steel bracket that would have two holes for better support... But that will be time consuming and probably serious overkill.
Tim
post #5 of 11 Old 12-27-2019, 09:27 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Doesn't sound like what you are comfortable with, but myself I'd fill the hole with my MIG or TIG, and redrill the correct hole.
tadawson is offline
post #6 of 11 Old 12-27-2019, 09:29 PM Thread Starter
I'm comfortable with quick and easy fixes. Lol
I'm liking the bronze bushing idea.. with some jb weld .
Name:	Pharos 11 Bushing Set_1577500191698.jpeg
post #7 of 11 Old 12-27-2019, 09:33 PM
Thanks (Given): 16
Thanks (Received): 86
Likes (Given): 241
Likes (Received): 202
Here is a previous discussion about it:
https://www.snowblowerforum.com/foru...00-series.html
db130 is offline
Thanks eyebolt thanked for this post
Likes eyebolt liked this post
post #8 of 11 Old 12-27-2019, 09:47 PM Thread Starter
Thanks DB130!
post #9 of 11 Old 12-28-2019, 03:34 PM
Thanks (Received): 7
Likes (Received): 61
Yes… Have a machinist make a bushing for you and you should be good… and in years from now, if there's some wear again, then just replace the bushing!
Claude.
2004 MURRAY BRUTE 10HP 29"
toofastforyou is offline
post #10 of 11 Old 12-28-2019, 05:44 PM
A "Good" Hardware Store will have an assortment available.
Jackmels is offline
