Craftsman 26" Snow Blower Starts fine - only on "run" - Snowblower Forum : Snow Blower Forums
post #1 of 3 Old 01-01-2020, 08:47 PM Thread Starter
Craftsman 247.889702 - When I set the dial to "choke", prime the carburetor 3 (or more times), pull the start cord (after finding TDC), the engine will not start.
But, when I set the dial to "run" and repeat the above, it starts easily on one pull.
I don't understand what the issue could be.
It's an MTD 370 SUB engine.
Any thoughts / comments?
TIA
Peabodyn is offline
post #2 of 3 Old 01-01-2020, 08:53 PM
If it was me I would just set it on run & run it. When that stops working then I would worry about it. That probably isn't the correct thing to do but that's me. hopefully it will get you threw the winter & run great & in the spring figure it out.
Bulldogge is offline
post #3 of 3 Old 01-01-2020, 09:00 PM Thread Starter
I tend to agree, but I'm giving the machine to one of my sons and want to make it perfect.
I bought it with a blown motor (connecting rod went through the crankcase right below the gas tank).
Found a new MTD motor for $150 and installed it today.
Will probably take off the shroud tomorrow and see if the choke assembly is set up correctly.
Thanks for the response
Peabodyn is offline
