Careful using Ultrasonic Cleaner, removed aluminum - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-03-2020, 09:41 AM Thread Starter
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
For those who have used an ultrasonic cleaner, if you have used a clear cleaner, after cleaning you will see aluminum particles, aluminum dust, in the bottom. You may want to reconsider using it and using a carb cleaner dunk tank instead or shortening the cleaning time, possibly 10 minutes. My ultrasonic cleaner without running, has a heater that will heat the fluid to 150-170 degrees. I put my carbs in, let it sit and soak until the temperature is up there, that will take several hours, then turn it on for 5-7 minutes.
JLawrence08648 is offline
Thanks Miles, orangputeh thanked for this post
Likes classiccat, aldfam4 liked this post
post #2 of 10 Old 01-03-2020, 11:10 AM
Thanks (Given): 63
Thanks (Received): 70
Likes (Given): 277
Likes (Received): 173
some of the dust could be aluminum oxide, which is white or gray powder, that comes off during cleaning. This is not necessarily bad, although the oxide layer on aluminum actually helps protect and seal the outer surface of aluminum. So once the oxide is removed, the remaining clean metal will oxidize again, creating another layer of aluminum oxide.
But your caution is warranted, and I only use softer soaps when cleaning carbs.
thanks.
Paul
paulm12 is online now
post #3 of 10 Old 01-03-2020, 11:47 AM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
Good advice JL! I've always worried about the shafts vibrating and eroding the opening...especially the throttle shaft.
I believe in good soak in carb cleaner followed by a hot/short ultrasonic bath in dawn dish soap to remove the organic residues and particulate.
('87 Toro 38150 826)
classiccat is online now
post #4 of 10 Old 01-03-2020, 07:14 PM
Likes (Received): 45
I've had good experiences with my ultrasonic cleaner. I didn't notice any metal flaking off. I have noticed that newer carbs are cast pretty shitty, I mean like mangled pretty much. It could be really cheap aluminum falling apart because there's impurities, contaminants, air pockets, etc..
ou2mame is offline
post #5 of 10 Old 01-04-2020, 01:49 AM
Thanks (Given): 48
Thanks (Received): 248
Likes (Given): 145
Likes (Received): 501
Used to have one of these big guys for cleaning large photofinishing processor racks. You could run virtually any ferrous or nonferrous metal through it without damage using SC52 Cleaning Concentrate, which is moderately acidic & formulated to strip metal oxides and metallic coatings. https://www.sharpertek.com/shclsoforreo.html
  • May be used on all ferrous and nonferrous metals:
    • Aluminum
    • Iron
    • Brass
    • Copper
    • Pewter
    • And other metals
https://catalog.upcorp.com/item/ultr...tems/up-5424-3
tabora is online now
post #6 of 10 Old 01-04-2020, 08:42 AM
Thanks (Received): 17
Likes (Given): 22
Likes (Received): 47
I use about a cup of Simple Green HD to 6 liters of water with good results. It is cheap and does not attack the aluminum. I have cleaned a couple hundred carbs and parts without an issue.
The heat is up to temp after only 10 minutes if you turn the ultrasonic on. The freq. action heats up the solution also.
strtch5881 is offline
post #7 of 10 Old 01-04-2020, 10:11 AM
Thanks (Given): 63
Likes (Given): 277
    • Aluminum
    • Iron
    • Brass
    • Copper
    • Pewter
    • And other metals
geez, you could just put the whole snowblower in that one.
tx.
Paul
post #8 of 10 Old 01-04-2020, 11:04 AM
Thanks (Given): 250
Thanks (Received): 46
Likes (Given): 745
Likes (Received): 135
hello forum, great topic. If I may, I would like to add a youtube clip of from guy who has some good ideas. The shop is called Steve's small engine saloon and is worth taking a look at. For Ultrasonic cleaners he fills up his tub with water but to keep the water clean he puts his parts in plastic containers with the cleaning solution added to it. He likes gasoline for top cleaner and others have suggested putting mineral spirits in the container.
Quick question about the ultrasonic cleaners. I use a shower filter in our shower which filters out hard water contaminants, when they are used they do a great job. Usually they are replaced after 6 months but can be expensive. I was wondering if the hard, possibly plastic cartridge could be cleaned and reused by putting it in the ultrasonic cleaner?
See photo of cartridge below.
Here is a link to Steve's ultrasonic video -
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
post #9 of 10 Old 01-04-2020, 08:08 PM Thread Starter
Thanks (Given): 97
Likes (Given): 76
The items you are cleaning are suppose to be suspended in the solution, for us, in a wire basket. If they are sitting in the bottom I've been told by the manufacturers and distributors, you will shorten the life of the transducers. Nothing can touch the bottom. Putting components in a glass container where the container is touching the bottom is not acceptable.
Thanks Miles thanked for this post
Likes strtch5881 liked this post
post #10 of 10 Old 01-05-2020, 03:34 PM
Thanks (Given): 250
Likes (Given): 745
JLawrence08648 take a look at the video, all items in the container are put in the basket, nothing is touching the bottom.
Toro - CCR 3650
Toro - CCR 2000
