Tecumseh Carb Leaks When Snowblower Tilted - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-03-2020, 12:43 PM Thread Starter
Hi Guys
I have a Sears snowblower with an 8hp Tecumseh engine. Carb is fully rebuilt by a local shop and the engine runs well. Issue is when I tilt the blower to move it when it’s not running, it leaks fuel from the choke/intake area. It doesn’t leak when running nor does it leak when not running if the blower isn’t tilted. Any thoughts on how to stop the leak?
Ccruji is offline
post #2 of 4 Old 01-03-2020, 12:59 PM
oneacer's Avatar
Thanks (Received): 148
Likes (Received): 540
Yeah, put an in-line shut off right below the tank.
Or take the carb off and fix it,
Or put a 12-15 dollar new carburetor on it.
oneacer is online now
post #3 of 4 Old 01-03-2020, 01:00 PM
Thanks (Given): 26
Likes (Given): 85
Sounds like they screwed up the float bowl gasket or float level. Take the bowl off, check the float level while you are there, and make certain the gasket is intact and correctly placed when you put it back together.
Or, take it back and ask them to do the work correctly . . .
tadawson is online now
post #4 of 4 Old 01-03-2020, 11:29 PM
ou2mame's Avatar
Thanks (Received): 7
Likes (Received): 45
If you paid them to do it, they should do it right. Temporary fix would be to put a fuel shutoff on the fuel line and run the carb empty.
ou2mame is offline
