John Deere 724D Sticks in Forward - Snowblower Forum : Snow Blower Forums
post #1 of 13 Old 01-06-2020, 10:01 AM Thread Starter
Likes (Given): 15
Likes (Received): 13
Hello and hopefully someone has experienced this before with either John Deere or Ariens snowblowers (I believe the JD is actually an Ariens painted green). My JD 724d keeps sticking in forward gear with the traction control lever fully released. The drive does eventually release, but happens again shortly thereafter. Backed off adjustment on drive lever cable as well with no help. Manual and forum searches didn't help. Any help appreciated. Thanks!
NWRider is offline
post #2 of 13 Old 01-06-2020, 11:00 AM
Thanks (Given): 175
Likes (Given): 465
Likes (Received): 1044
Read this thread and also watch the vid attached in post #3
https://www.snowblowerforum.com/foru...age-drive.html
Thanks Kiss4aFrog, NWRider thanked for this post
post #3 of 13 Old 01-06-2020, 11:15 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
And welcome to the SBF!!!!
2019 Ariens Compact 24...
penna stogey is offline
post #4 of 13 Old 01-06-2020, 11:42 AM Thread Starter
Likes (Given): 15
That video looked helpful and I will double check inside the transmission for any issues. Thank you!
NWRider is offline
post #5 of 13 Old 01-06-2020, 12:36 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to SBF NWRider
Let's us know if it needed cleaning and lubing on that shaft and if that cures your problem.
post #6 of 13 Old 01-06-2020, 01:01 PM Thread Starter
Likes (Given): 15
Nothing seemed to be hanging up and the wheels spun freely through all gears. Shaft also seems to be adequately lubed. When traction lever isn't applied there is a sufficient gap between the friction disc and wheel. Only seems to happen when I am operating the machine and it does it about 75% of the time.
ID:	162173   Click image for larger version
NWRider is offline
post #7 of 13 Old 01-06-2020, 01:23 PM
Thanks (Given): 590
Likes (Given): 4371
I think I misunderstood at first. Are you saying it stays in gear after you've released the drive lever ??
If so it might be that the drive disc is sticking and the springs can't pull it back all the time. Or that once engaged it sticks/jams then. I'd try to lubricate the shaft right under the drive disc where it's supposed to slide inside the bearing. I'd check the drive plate. If you try to wiggle it there shouldn't be much movement. Maybe the bearing or mounts are worn or maybe just needs a little lube.
In the pictures it's hidden by that green plate.
https://partscatalog.deere.com/jdrc/.../pgId/26753568
post #8 of 13 Old 01-06-2020, 01:45 PM Thread Starter
Likes (Given): 15
It does and I'll give that a try. Sounds like that might be a fix since it happens intermittently.
NWRider is offline
post #9 of 13 Old 01-06-2020, 02:17 PM
Thanks (Given): 590
Likes (Given): 4371
You should also check that friction disc. I can't tell from the photo how much rubber you have left. If it's well worn and not much rubber is left it makes that plate have to travel further to make contact with the disc.
Here is a photo of a new one for comparison.
The original PN was AM123355 and the substitution is M110594 https://partscatalog.deere.com/jdrc/.../pgId/26724537
post #10 of 13 Old 01-06-2020, 05:09 PM Thread Starter
Likes (Given): 15
Okay, went back in and lubricated the shaft under the drive disc like you suggested and so far, so good! Used a spray lubricating oil and tested it for about 10 minutes with no hang ups. Temperature is currently about 30 degrees, so not sure if that shaft will hang up again if it gets real cold? Also, friction disc rubber appears to be okay (replaced it about 4 years ago).
NWRider is offline
