Snapper I 722 Discharge Chute - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-08-2020, 08:12 PM Thread Starter
Where can I find a discharge chute for a Snapper I 722. Snapper does not seem to make it. Are there other brand chutes that fit the I 722. The used ones online seem to be markedly overpriced.
Also, is it possible to glue the old chute? What kind of adhesive would you suggest?
Thanks.
Streamline is offline
post #2 of 5 Old 01-08-2020, 09:03 PM
Likes (Received): 16
Is this a metal or plastic chute? cracked or what? can you post a pic or two? Without seeing I'll mention to make a sheet metal patch and pop rivet or use like machine screws and fender washers. I've done this by first cutting a thick paper pattern for the patch I need then transfer it onto the sheet metal then cut it out and form the metal to the shape you need.
cdestuck is offline
post #3 of 5 Old 02-12-2020, 08:22 PM Thread Starter
Chuck,
Thanks for taking time to reply. The chute is a platsic chute. It is shattered near the base and does not seem to be repairable. It would seem that other chutes might fit it, i.e. MTD, but I haven't seen that information online.
post #4 of 5 Old 02-12-2020, 08:58 PM
tabora's Avatar
Thanks (Given): 47
Thanks (Received): 248
Likes (Given): 143
Likes (Received): 500
What is the ACTUAL Snapper model number?
tabora is online now
post #5 of 5 Old 02-13-2020, 11:28 AM
I have had pretty good results with patching plastic components with sheet metal and rivets or small bolts with lock washers. If it’s a area that you can do this, make a pattern out of paper, transfer it to the sheet metal ant cut out. If this isn’t workable on your crack I hope ya make out finding a used piece.
cdestuck is offline
