Briggs 1100 snow Series no control Governor - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 01-10-2020, 04:54 PM Thread Starter
I need help yet again. I bought a 2 stage snow Blower off a guy call could not get it started because of the Plastic On/ off key was removed. He tore apart everything and try to put everything back together. Well he did a good job of putting everything back together except the throttle/governor linkage, he had it so jacked up that it would not move in places that it should’ve never been. I put it back To where I thought would be a good start but I have no control of the governor who wants to run 100% wide open even with the spring that adds tension to the different holes. I know I need to get a new spring that wraps through the control linkage, that is all jacked up but where do I find or how do I start to adjust the governor? It’s a great snowblower in great shape it just a guy had no clue what he was doing. Thanks again
fespo is offline
post #2 of 15 Old 01-10-2020, 05:23 PM
Grunt's Avatar
Thanks (Given): 268
Thanks (Received): 326
Likes (Given): 3250
Likes (Received): 660
Page 91 figure 1 shows the correct setup.
https://drive.google.com/drive/folde...EJwRjlrTnFmVWc
Likes fespo liked this post
post #3 of 15 Old 01-10-2020, 07:23 PM
Thanks (Received): 22
Likes (Given): 40
i havethe install sheet at work if i can dig it up tomorrow ill get some pics of it for you
arienskids is online now
post #4 of 15 Old 01-11-2020, 12:41 AM
Thanks (Given): 20
Thanks (Received): 56
Likes (Given): 78
Likes (Received): 115
Looks like the spring is hung up on the fixed point, left side of pic. Try sliding it over the T, so the spring moves freely around the anchor.....for starters.
GLuck, Jay
JayzAuto1 is offline
post #5 of 15 Old 01-11-2020, 12:37 PM
Motor City's Avatar
Thanks (Received): 53
Likes (Received): 65
It looks like the right end of the spring is in the wrong hole. It looks like it was in the hole I have the arrow at. And as stated above the other end is not installed correctly. To fine tune adjust the rpm's you can bend the tab the left side of the spring attaches to.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #6 of 15 Old 01-11-2020, 11:11 PM Thread Starter
I just took a picture to ask about the governor, I did order a new spring and it is all jacked up from the other homeowner. I just have it laying there until I get a new spring then I will remove the carb and install correctly Thanks for your help everyone!!!
fespo is offline
post #7 of 15 Old 01-17-2020, 10:24 AM Thread Starter
The new spring did come in yesterday and I installed this morning and I’m having the same issue, the engine is just running wide open. Any other thoughts?
fespo is offline
post #8 of 15 Old 01-17-2020, 12:07 PM
Grunt's Avatar
Thanks (Given): 268
Likes (Given): 3250
You are going to need another spring to make the linkage work. I thought you were ordering the small spring as shown by the red arrow. Right now, without the spring, the governor is not being controlled. Your linkage on the right. Sorry, I don't know the part number.
ID:	162595   Click image for larger version
Likes oneboltshort liked this post
post #9 of 15 Old 01-17-2020, 02:30 PM Thread Starter
Ok thanks, I will look that up.
Well,Now I know why I didn't order it, because it's not showing on my parts diagram, Im trying everything I can think of to look for that spring but it's not showing up on anything. Thanks again
fespo is offline
post #10 of 15 Old 01-17-2020, 04:33 PM
db130's Avatar
Thanks (Given): 16
Likes (Given): 240
Likes (Received): 200
I did an ebay search for "briggs governor spring" and found something similar
https://www.ebay.com/itm/Governor-Sp...IAAOSwrcReIdkW
I hope that helps you.
db130 is online now
Thanks fespo thanked for this post
