John Deere Auger Gear Lube - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-11-2020, 03:26 PM Thread Starter
Likes (Given): 15
Likes (Received): 13
Very warm day today so I decided to do a little maintenance to the JD 724d (I believe it is actually made by Ariens and it is their ST724). The machine is either a 2001 or 2002, so one of the things I decided to do was change the auger gear lube. The lube came out looking terrible, it had a very light brownish milky appearance. Does anyone know if the original lube is supposed to look like that or did some condensation get inside the auger housing and cause this? The new gear lube that I topped it off with looked totally different.
NWRider is offline
post #2 of 5 Old 01-11-2020, 04:30 PM
johnwick's Avatar
Thanks (Received): 15
Likes (Given): 32
Likes (Received): 40
The gear oil in my newer Ariens looks like red motor oil only thicker. Itís not a grease.
johnwick is online now
post #3 of 5 Old 01-11-2020, 08:39 PM
badbmwbrad's Avatar
Likes (Received): 69
Emulsified water in oil gives it a "chocolate milk" appearance.
badbmwbrad is offline
Thanks NWRider thanked for this post
post #4 of 5 Old 01-11-2020, 09:45 PM
RC20's Avatar
Thanks (Received): 14
Likes (Received): 79
You got a bit of water in it but not a big deal.
I am just pondering doing the Yamaha after 22 years.
I have seen cars with 100K on the rear end (back when they had rear drive) and it looks awful but even that heavy strain application it was still doing fine.
I would put synthetic in there just because it helps the turning if its cold. Mobile is good but any mfg gear lube is fine
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #5 of 5 Old 01-11-2020, 09:51 PM Thread Starter
Likes (Given): 15
Yes, that's exactly what it looked like.
NWRider is offline
