Briggs "900" OHV No-Start, Tried Everything, Any Tricks With These Models? - Page 5 - Snowblower Forum : Snow Blower Forums
post #41 of 56 Old 02-04-2020, 03:53 PM
Thanks (Given): 20
Thanks (Received): 14
Likes (Given): 90
Likes (Received): 71
I donít know if it was mentioned earlier, does the Woodruff key that secures the flywheel over the ignition points have any bend on it? It only takes a very,very small bend to misplace where the magnets are supposed to be for maximum spark.
This is a common reason why many lawn mowers fail to start even though the have fuel and spark.
foggysail is offline
post #42 of 56 Old 02-04-2020, 04:11 PM Thread Starter
Likes (Received): 7
The keyways in the flywheel and the crank are perfectly centered when you remove the nut.
The cam gear is definitely rotated on the shaft, by at least 90į. Here are a couple of pictures:
- Eric
Name:	Briggs Cam 3A.jpg
ID:	163557   Click image for larger version
Name:	Briggs Cam 3B.jpg
MDchanic is offline
Post Thanks / Like - 0 Thanks, 4 Likes, 0 Dislikes
post #43 of 56 Old 02-04-2020, 06:00 PM
Likes (Given): 31
Likes (Received): 19
Eric, It's been a while since I did one of these but I think the plastic one is discontinued and even when you order it, you get a steel one. I think I got a note in the box and may have said 693404 was now 693404a or similar.
Glad you got to the issue
oneboltshort is offline
post #44 of 56 Old 02-04-2020, 08:48 PM
Thanks (Given): 166
Likes (Given): 166
Likes (Received): 7
Have you checked the gas cap vent ? Take cap off, let vacuum escape, try again . Consumed fuel forms a vacuum as level drops. Gas Cap is vented to prevent this.
Fat City is online now
post #45 of 56 Old 02-05-2020, 08:47 AM
Thanks (Given): 16
Thanks (Received): 63
Likes (Given): 493
Likes (Received): 157
MDchanic
thanks for the photo's and report . onebolt thanks for the part number supersede number info ,
never could understand why briggs had to play with plastic to start with, heck even the bigger singles had plastic pins holding the counter weights in place
87powershiftx2 is offline
Likes Shovel liked this post
post #46 of 56 Old 02-05-2020, 02:47 PM
Jesse11B's Avatar
Likes (Given): 25
Man, this has been a painful thread to read through. Mechanical failure of steel parts is one thing, but plastic parts in an engine is painful to see. Thanks for the detail in your postings. Good luck with it!
Jesse11B is offline
post #47 of 56 Old 02-05-2020, 04:07 PM
Thanks (Given): 23
Thanks (Received): 53
Likes (Given): 80
Likes (Received): 88
I was shocked as well.. the engine had very little usage.
I don't think they all fail that fast.. he just had some terrible luck
Shovel is online now
post #48 of 56 Old 02-06-2020, 09:51 AM
Its all about the Luck.
Oliver Jake is offline
post #49 of 56 Old 02-06-2020, 10:33 AM
Sid
Thanks (Given): 10
Thanks (Received): 25
Likes (Given): 30
Likes (Received): 42
Second time this winter, The dreaded Murphy's law.
Sid
'66 Sears/Murray 26"
'71 Jakobson 17 SnowBlitz
Sid is online now
post #50 of 56 Old 02-06-2020, 12:21 PM Thread Starter
Likes (Received): 7
Originally Posted by oneboltshort View Post
... I think the plastic one is discontinued and even when you order it, you get a steel one.
OneBolt, Unfortunately, No.
Here's the new part:
The cam came in 1 day. Now I'm waiting for the paper gasket and the output shaft seal (Might As Well...), and I'll slap that bad boy back together.
- Eric
MDchanic is offline
