Fuel System - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 01-17-2020, 05:10 PM Thread Starter
Fuel System
My snow blower (Poulan 27) would start and die after 30 seconds. Drained the fuel and replaced with fresh fuel. Dies after 2 minutes. What I noticed when draining fuel was it did not drain in a steady stream. There was 2 litres of fuel in it. The stream was dripping. Took 10 minutes to drain the tank. What is restricting the fuel flow, as I think that is my issue?
Snowman7 is offline
post #2 of 8 Old 01-18-2020, 12:01 AM
Thanks (Given): 587
Thanks (Received): 769
Likes (Given): 4352
Likes (Received): 1734
to SBF Snowman7
The vent in the gas cap might be plugged. Remove the cap and see if it flows better.
Something in the tank that's covering the fuel outlet.
How old is the machine ? Maybe the fuel line is deteriorating on the inside.
post #3 of 8 Old 01-18-2020, 12:07 AM
ST1100A's Avatar
Thanks (Given): 201
Thanks (Received): 126
Likes (Given): 413
Likes (Received): 266
Sounds almost like the float level is set too low, not allowing enough fuel into the bowl fast enough to keep it running at a higher speed. It can't recover fast enough by re-filling the bowl with fuel quick enough when the engine uses the fuel up in the bowl.
It might need a new needle seat or adjustment of the float possibly if you noticed the drainage problem from the carb bowl drain.
ST1100A is offline
post #4 of 8 Old 01-18-2020, 12:27 AM
Thanks (Given): 587
Likes (Given): 4352
Was that out of the hose when disconnected from the carb or through the carb with the float bowl removed or screw out of the float bowl ?
post #5 of 8 Old 01-18-2020, 12:50 AM
ST1100A's Avatar
Thanks (Given): 201
Likes (Given): 413
Another possibility, if that's a Tecumseh engine with the fuel line squeezed between the cooling fins behind the flywheel, they were known for swelling shut, causing low fuel flow problems. Then he would have to replace the fuel line from the fuel tank to carburetor.
A possibility.
ST1100A is offline
post #6 of 8 Old 01-18-2020, 04:26 AM
Likes (Received): 12
to SBF Snowman7
First thought right there , just did that with mine . Although ..... it didnít take more than 20seconds to konk out with a full tank. Then itís on to fuel flow as others have said. Somethings stopping fuel from getting to where it needs to go fast enough .
Iíd pull the line off the tank (full tank so it flows best) at the carb then see if it flows real solid stream. If it peters out take the cap off and if it immediately Flows full youíve found your culprit , the cap. if itís wimpy all the time cap or off look to the line being jammed between the cooling fins as others have mentioned.
2002 Ariens 932-101
driz is offline
post #7 of 8 Old 01-18-2020, 05:27 AM
penna stogey's Avatar
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
First post needs a hearty welcome...Hearty Welcome to the SBF from Gettysburg.
2019 Ariens Compact 24...
penna stogey is online now
post #8 of 8 Old 01-18-2020, 07:28 AM
Thanks (Received): 99
Likes (Given): 729
Likes (Received): 255
going by the poulan web site a 27 uses a 254 cc LCT engine , that motor has a screw in tank nipple that is also a fuel filter, which uses a ultra fine plastic screen to filter the fuel,
many times with low flow out of the tank is not corrected by losing the gas cap. it is clogged and needs to be replaced. this filter is so fine it is easy to clog and many forget or don't know it's there, as it simply looks like a connecting tank nipple
in that case in the shop we replace the filter/nipple and hose to the carb,
87powershiftx2 is offline
