Honda hs1132 tread repair - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 01-19-2020, 12:05 PM Thread Starter
I am trying to replace a tread on a Honda hs1132. Does the lock nut loosen counterclockwise?
JJSIII is offline
post #2 of 4 Old 01-19-2020, 02:04 PM
orangputeh's Avatar
Thanks (Given): 763
Thanks (Received): 236
Likes (Given): 1584
Likes (Received): 1681
the lock nut is underneath that cross plate and you do not need to loosen most times. it does go counter. all you usually have to do is loosen up both top nuts almost all the way to loosen track enough to remove.
an easier way is to remove both wheels after loosening up adjustment bolts and removing and replacing track with wheels as one unit. much easier.
plus if you leave the lock nut alone you will have your stop for almost perfect adjustment.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #3 of 4 Old 01-19-2020, 02:43 PM Thread Starter
Thanks!
JJSIII is offline
post #4 of 4 Old 01-19-2020, 05:15 PM
orangputeh's Avatar
Thanks (Given): 763
Likes (Given): 1584
Thanks!
i should have posted this pic. just did the same thing 2 days ago. had to replace broken adjust bolt on free axle.
i used that 1/2 inch sander to sand welds off bottom of bolt to punch it out and did not have to remove axle. the axle laying on top was just to show end of bolt welds for reference. the track had come off because of the broken bolt made it too loose on that side.
the deflection of tracks when all adjusted up properly should be no more than 3/4-1 inch when machine is on ground and measurement taken from middle top of track.
Thanks Honda1132 thanked for this post
