Broken snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 22 Old 01-19-2020, 12:32 PM Thread Starter
Broken snowblower
This is what happened today while clearing snow ,heard ticking them shrapnel flying 🙂 ,it is a 20ish year old Mastercard with a techumseh engine.Can anyone tell why this happened and is it worth fixing thank you
carp130 is offline
post #2 of 22 Old 01-19-2020, 12:35 PM
Thanks (Received): 152
Likes (Received): 549
If I had to guess, someone at some point ran it without oil or very low on oil, or even maybe tried 30W oil in the winter.
Just swap it out for a 99.00 Predator and your all set for a long time.
oneacer is online now
post #3 of 22 Old 01-19-2020, 12:47 PM
Thanks (Given): 97
Likes (Given): 76
Likes (Received): 463
It may have happened because of too high RPMs or damage had occurred previously due to low oil and it was inevitable.
Is there a Harbor Freight near you? Chinese Predator engine for $99.
post #4 of 22 Old 01-19-2020, 02:19 PM Thread Starter
Ok.thank you ,how hard is it to do the sawp
carp130 is offline
post #5 of 22 Old 01-19-2020, 02:21 PM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Welcome to the SBF from Gettysburg
2019 Ariens Compact 24...
penna stogey is online now
post #6 of 22 Old 01-19-2020, 02:43 PM
Thanks (Received): 14
Likes (Given): 36
Likes (Received): 28
Can you remove the belt cover and snap a picture of the belts?
Might not be so easy if it's dual shaft.
oneboltshort is offline
post #7 of 22 Old 01-19-2020, 02:54 PM Thread Starter
I'll take a look ,may take me a few days to get at it .
carp130 is offline
post #8 of 22 Old 01-19-2020, 03:19 PM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
unless these old eyes are deceiving me,i sure don't see a lot of oil out of that aerated block.it looks way to dry. time for a repower
87powershiftx2 is offline
post #9 of 22 Old 01-19-2020, 03:21 PM Thread Starter
Here are the pics
ID:	162765   Click image for larger version
carp130 is offline
post #10 of 22 Old 01-19-2020, 03:23 PM Thread Starter
All I know is I checked the oil last week and the dipstick said full ,then when I was snow blowing today I heard a pinging/knocking sound and the hoe blew out
carp130 is offline
