Simplicity Snow-Away 1008 Pulley Broke - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-20-2020, 10:58 AM Thread Starter
The engine pulley on my Simplicity Snow-away 1008 recently broke while I was using the machine which caused the belt to break off as well. I got a new belt, but after doing some fairly extensive searching online, I haven't been able to come up with a new pulley. The part number listed is 173941 and I cant find it anywhere ! Does anyone know if there is a interchangeable part for this or what I should do? It has a 8hp briggs and stratton on it I believe with a 1" keyed shaft. The pulley measures ~2.13" on the small OD and ~3.09" on the large OD. The overall width is 1.82". Any help would be greatly appreciated. Thanks!
Adam Bombardo is offline
post #2 of 5 Old 01-20-2020, 11:42 AM
Thanks (Received): 212
Likes (Received): 767
Go to Tractor Supply and get a generic pulley
cranman is offline
Thanks Adam Bombardo thanked for this post
post #3 of 5 Old 01-20-2020, 12:05 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post...Greetings from Gettysburg, Penna.
2019 Ariens Compact 24...
penna stogey is online now
post #4 of 5 Old 01-20-2020, 12:12 PM Thread Starter
I tried going to Norther Tool but the only pulleys they have are the single ones, I need one with two different sized pulleys on the same part. Does Tractor supply have doubles?
post #5 of 5 Old 01-20-2020, 12:25 PM
Thanks (Received): 32
Likes (Given): 45
Likes (Received): 52
Use single pulleys. You can usually figure out some way to install two single pulleys on the engine shaft so they line up properly
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
