Adjusting friction drive on 1973 Ariens - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 01-21-2020, 04:13 PM Thread Starter
I have a 1973 Ariens (model # 910008) which I re-powered last fall). I think I need to adjust the friction drive, because I was experiencing some slippage when I used the blower last week. I have the original leaflet sized owners manual that came with the blower, but the instructions in it to adjust the friction drive are missing information (such as in what direction to turn the adjustment rod in when you are making adjustments) and shows a diagram of the adjustment mechanism which does not match what is on my model.
Specifically, the diagrams show a housing on the exterior rear of the tractor unit where they indicate the adjustment rod and set screw can be accessed, On my blower, there is no such mechanism. I can access the adjustment rod by removing the rear/bottom cover on the tractor unit, but there is no set screw mechanism in there. The adjustment rod appears to have sleeve on it with nut at each end, which I suspect may be the the means to both adjust the rod to fix the slippage and secure the setting. But again I don't even know what direction to turn the rod.
Any suggestions on how to make the adjustment (or ideas on where that information resides) would be appreciated.
mikeythemars is offline
post #2 of 5 Old 01-21-2020, 04:31 PM
Thanks (Received): 149
Likes (Received): 543
I believe that is a 10000 series, and the friction disc against the drive plate is always engaged, unless placed in neutral for free wheeling, or the clutch lever is engaged.
That friction disc is either worn, or the main spring on the friction disc mechanism is worn, thus giving improper tension. There is a slight adjustment on the left side clutch lever rod, to adjust the pull back tension of the Friction Disc, and the right side shifter placement rod can be adjusted for the placement of the friction disc on the drive plate, thus giving you your gears, depending where on the disc the friction drive makes contact.
oneacer is online now
Likes mikeythemars liked this post
post #3 of 5 Old 01-21-2020, 10:38 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
73/74 isn't like that - it's 'squeeze to drive' . . .
tadawson is offline
post #4 of 5 Old 01-22-2020, 07:44 AM
Thanks (Given): 11
Thanks (Received): 111
Likes (Given): 19
Likes (Received): 311
Does this have the information you need? https://apache.ariens.com/manuals/STOI-72.pdf
Otherwise post some pics of the mechanism and hopefully we can figure it out!
ELaw is offline
post #5 of 5 Old 01-23-2020, 09:07 PM Thread Starter
Yes, thank you! that did have the specific information (including a diagram) I needed to fix the issue I was having with the traction drive in my 1973 Ariens.
I followed the Ariens instructions in what you sent to the letter as follows:
- tip the entire blower up so that the auger and impeller unit are facing down on the floor.
- unbolt and remove the rear/pan cover from the tractor unit.
- loosen the nut (referred to in the instructions as a "jam nut") that is at the bottom of the sleeve on the adjustment rod.
- put the blower into fourth gear.
- then go through a tweaky process of tightening the adjustment rod, via the bolt at the top of the sleeve, while having to simultaneously look at the point where the friction disc meets the plate. That is because you have to tweak the adjustments on the rod until there is only a half a millimeter of open space between the disc and plate (yes, that half mm spacing is the spec in the Ariens instructions) and I'm glad I had my set of spark plug gap shims so I could actually measure things to make sure I was setting that microscopic amount of air properly.
- then re-tighten the jam nut
- then bolt the rear pan/cover back on.
Drive now properly engages with no slippage.
