Track drive MTD 8/26 - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 01-26-2020, 09:04 AM Thread Starter
MLM
Anyone have an idea how many foot/lbs on track tensioning eye bolt? It's a 1997 model
MTD 8/26, two-stage, track drive,
Model 317E742F352
1652795
serial. 1H066B40122
Can't be much I wouldn't think.
One 3/8—16 bolt per side.
Thanks,
MLM
MLM is offline
post #2 of 6 Old 01-26-2020, 02:04 PM
Thanks (Given): 589
Likes (Given): 4364
Likes (Received): 1742
I didn't find a place giving specs for your machine.
In my world I'd just get it tight and if I was worried I'd hit it with a drop or two of thread locker.
Couple tables if you search.
https://www.boltdepot.com/fastener-i...ed-Torque.aspx
23 if it's a grade 5 and 33 if it's a grade 8 lb/ft
post #3 of 6 Old 01-26-2020, 03:47 PM
Thanks (Received): 98
Likes (Received): 260
You should be able to find specs on MTD website. I believe it is not listed as ft-lbs, but by belt flex when pushing on it with so much pressure.
RIT333 is offline
Likes 2muchsnow liked this post
post #4 of 6 Old 01-26-2020, 06:47 PM
Thanks (Received): 11
Likes (Given): 28
Likes (Received): 32
I would think this is the answer if it's anything like the track machines I've worked on.
Sent from my Pixel 4 XL using Tapatalk
2muchsnow is offline
post #5 of 6 Old 01-26-2020, 09:49 PM
Thanks (Received): 14
Likes (Received): 80
Snug without being tight.
Yamaha lists 11 lb weight in the middle and 1/3 to 1/2 inch deflection.
Gentle push of the hand in the middle is a good rule of thumb (er hand)
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #6 of 6 Old 01-27-2020, 07:06 AM
There should 1/2" deflection in the middle with 15# of force - per MTD.
RIT333 is offline
