Snowblower backfire on Choke outlet - Snowblower Forum : Snow Blower Forums
post #1 of 34 Old 01-27-2020, 02:27 PM Thread Starter
Hello All, I have been searching and doing little adjustments on this issues
I have a Toro ccr 6053 (38575) I got this unit fairly cheap. Old owner said they havent used it in over a year.
Perfect carb repair I thought
I have changed the spark plug, cleaned the carb x 4, put new gas in
The unit tries to start. I can see backfire on the outlet of the choke area. It never really started. While I crank it without fully pulling I can see fuel leaking out of the choke outlet as well.
Do I need a completely new carb? or am I looking at something deeper (valve, timing issues?)
Raymund Aguilar is offline
post #2 of 34 Old 01-27-2020, 02:39 PM Thread Starter
post #3 of 34 Old 01-27-2020, 02:56 PM
Thanks (Received): 82
Likes (Given): 76
Likes (Received): 287
hows the oil in it look? looks like a lot of gas coming out of the carb. i would maybe pull the valve cover and check the valves to make sure the valves are moving as they should and maybe check the valve lash while in there.
yardworks 31AH6WKF515
crazzywolfie is online now
post #4 of 34 Old 01-27-2020, 03:15 PM
Thanks (Received): 14
Likes (Given): 36
It sure looks like it's firing with the intake open.
I'd do as stated and pop the valve cover to see what's going on. From the IPL pricing, I would guess the cam is plastic.
https://www.partstree.com/models/oh1...ist-ohsk5xa-0/
oneboltshort is offline
post #5 of 34 Old 01-27-2020, 03:20 PM
Thanks (Given): 33
Thanks (Received): 66
Likes (Given): 116
Likes (Received): 138
Check for a critter nest in the exhaust
Shovel is offline
post #6 of 34 Old 01-27-2020, 03:23 PM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3364
Likes (Received): 683
Welcome to SBF Raymond. Here is a link to the Tecumseh OHV service manual. I also would check the valve clearances and look for proper operation. Could be a bent push rod, bad cam shaft or hopefully, valves out of adjustment, which is .004 thousandths each valve. I think your OH195 motor is the same as an OHH-OHSK55-70 in the manual.
http://www.barrettsmallengine.com/ma...alvemanual.pdf
Likes dbert liked this post
post #7 of 34 Old 01-27-2020, 03:45 PM Thread Starter
thanks for the prompt reply guys. So getting a new carb wouldn't solve this? (looking for an easy way out). I spray started inside the engine and it still would start. Ill open it and see. how diff is this process? valve replacement and etc
post #8 of 34 Old 01-27-2020, 04:52 PM
Thanks (Given): 33
Likes (Given): 116
Before you go any further check for a critter nest in the exhaust..I pulled on a rope for three hours one time. ...the engine was doing the same thing as in your video.
The intake valve not fully closing can also cause the issue you are experiencing.
Not sure about your particular engine... But I have see spark plugs that were to long installed and a valve hit it upon opening.
A sheared flywheel key can throw your ignition timing way off(if its electronic)
If it has points it usually won't have a spark though.
A soft pull on the rope with the ignition off should tell you if the intake valve is not closing properly..very low compression and you can hear it coming back out of carb.
Also if the machine did not have an air filter ..a critter could have built on the intake side and a piece of debris can be on the valve not letting it close fully.
Shovel is offline
post #9 of 34 Old 01-27-2020, 05:09 PM Thread Starter
Thanks. I pulled it and the spring was loose. the washer that is holding the valve connected was off and sheared. I am hoping everything else is good if I replace that.
Thanks Dannoman thanked for this post
Likes Dannoman liked this post
post #10 of 34 Old 01-27-2020, 05:19 PM Thread Starter
some pics
ID:	163207   Click image for larger version
