HF Predator drain plug - Snowblower Forum : Snow Blower Forums
post #1 of 12 Old 01-30-2020, 04:38 PM Thread Starter
I just installed a Predator 212cc on a Craftsman blower. The original LCT oil drain was (conveniently) to the rear. The Predator drains are on each side. Looking to replace the drain plug with a pipe nipple&cap or drain valve.
So I can get ready ahead of time....
Does any one know the thread diameter and pitch on the oil drain plug?
If so please let me know.
burt8810 is offline
post #2 of 12 Old 01-30-2020, 04:50 PM
Thanks (Received): 151
Likes (Received): 546
If I remember, I believe it was 10mm ….
oneacer is online now
post #3 of 12 Old 01-30-2020, 04:57 PM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 747
Likes (Received): 268
think your right! it's NOT a pipe thread for sure 10mm seems what they look like , a toro loncin ## 121-0341 DRAIN PLUG KIT might work ??
87powershiftx2 is offline
post #4 of 12 Old 01-30-2020, 05:01 PM
Likes (Received): 19
Please do report back to the forum if you find a source for that 10mm thread pipe. I once found a custom on ebay but it was aluminum and too thin to survive torquing it into the case.
cpchriste is online now
post #5 of 12 Old 01-30-2020, 05:04 PM
@cp,
Actually, it was an aluminum one to pipe thread that I used … I think it was a little pricey, like 7dollars?
post #6 of 12 Old 01-30-2020, 05:34 PM
@cp,
Sounds about right - but didn't work for me.
How about this homemade solution?
Mirror adapter https://www.ebay.com/itm/Emgo-Motorc...0/172151086054
Drill through 1/8" diameter if hole not already there. Drill and tap hex end to 1/4 pipe thread. Insert standard pipe and cap.
Any pre-made solutions out there? Predator hot-rod guys?
Thanks burt8810, Danw thanked for this post
post #7 of 12 Old 01-30-2020, 05:36 PM
Thanks (Received): 32
Likes (Given): 46
Likes (Received): 52
Lots of people use this (I do), easy to install
https://www.homedepot.com/p/10-mm-Oi...1010/206184635
Also, I think there's a thread on this site where threaded brass tubing and fittings from home depot was used to bring the oil drain out the back, but I bet that's expensive.
There's also this adapter.
https://www.ebay.com/itm/10mm-x-1-25...r/324024752677
1997 Toro 724
1997 Toro 824XL Power Throw
toromike is online now
post #8 of 12 Old 01-30-2020, 05:50 PM
Yeah, that one from ebay is the one I used.
post #9 of 12 Old 01-30-2020, 05:51 PM
[quote
https://www.ebay.com/itm/10mm-x-1-25...r/324024752677[/quote]
Beat me to it!
Here's another one made from SS https://www.ebay.com/itm/Honda-GX120...2/372711097267
I'd be very careful torquing the above aluminum one - depending on the through hole diameter.
post #10 of 12 Old 01-30-2020, 05:59 PM Thread Starter
Going with the ebay above. https://www.ebay.com/itm/10mm-x-1-25...r/324024752677
Sorry for starting this thread my question was answered in a 2014 post. I searched here but found it with Google.
Oh well
(Edit: added URL )
burt8810 is offline
