Craftsman Part Needed - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-02-2020, 09:11 AM Thread Starter
Hi there,
I have one of this old single stage Craftsman snowblowers. It’s just a single stage but it chugs along well. Even the electric start still works. Model number is C944 53324. Recently the part I call the clutch started slipping due to wear. There is a lever down near the drive shaft that engages it. I have photos. I have tried to find the part with no luck. Our local parts shop says it’s too old. New to this site so I apologize if this is not posted properly.
post #2 of 5 Old 02-02-2020, 09:44 AM
penna stogey's Avatar
Thanks (Received): 28
Likes (Given): 140
Likes (Received): 56
Throwing out the welcome mat for your first post...Hearty welcome from the Burg!
2019 Ariens Compact 24...
penna stogey is offline
post #3 of 5 Old 02-02-2020, 09:45 AM
Thanks (Received): 32
Likes (Received): 75
You may be able to locate a machine to buy for parts but finding a part is unlikely.
Tony P. is offline
post #4 of 5 Old 02-02-2020, 09:54 AM
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 459
Post several pictures of the machine and the part you need, we may be able to match it. Murray made many of the older Craftsman machines.
post #5 of 5 Old 02-02-2020, 09:58 AM
Thanks (Given): 585
Thanks (Received): 761
Likes (Given): 4314
Likes (Received): 1715
to SBF Pat
It helps a great deal to know where you are. Something you can add to your profile but going into the "User CP", upper right of the screen under the search box.
Since your model starts with a "C" I would guess it's Canadian so it's going to be hard for most of us (U.S.) to try and look it up.
Any chance you have a part number ? Photos would be a big help.
