Toro CCR2000 - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 02-07-2020, 04:15 PM Thread Starter
Toro CCR2000
My 20+ year old Toro CCR2000 quit on me today. Got most of the driveway finished and the machine started to hunt like it was low on fuel, it finally quit, I filled it up while still warm and would not restart unless I gave a it squirt of carb cleaner then it would die.
Fuel problem? Never had a problem with this before. I'll pull the fuel line off the carb to check the filter???
frednethel is offline
post #2 of 5 Old 02-07-2020, 04:32 PM
Thanks (Given): 250
Thanks (Received): 46
Likes (Given): 745
Likes (Received): 135
Original fuel lines? Might want to check those also, they breakdown over time and could cause problems in fuel delivery. My Toro CCR - 2000 is about 27 years old and still going strong.
Ariens - 924086 - ST1028
Craftsman - 88934 - 10HP 28"
Toro - CCR 3650
Toro - CCR 2000
aldfam4 is online now
post #3 of 5 Old 02-07-2020, 04:39 PM
Thanks (Given): 20
Thanks (Received): 35
Likes (Given): 59
Likes (Received): 219
you can pull the line off the carb and see if its flowing enough fuel to fill the carb. if it is you will need to take the carb off or possibly just the bowl and see if the float is acting like it should.
Toro 621 6hp 4 cycle ....Craftsman SS ???
....Honda HS624 GX160 Toro 828 lxe Tecumseh 8hp
Snowbelt_subie is offline
post #4 of 5 Old 02-07-2020, 05:59 PM
Mine is not quite that old but it's worth keeping. Just put on new paddles, scrapper bar, wheels and belt last year. I'll pull the fuel line off at the carb to see if the carb is getting gas. I suppose it is foolish to ask if there would be available a rebuild kit for the carb.?
Fred Mertz is offline
post #5 of 5 Old 02-07-2020, 07:46 PM
Thanks (Given): 250
Likes (Given): 745
Check out this guy "sixtyfiveford" on YouTube, here is the link:
He tears down and cleans the Suzuki Mikuno carb you may have.
Toro - CCR 3650
Toro - CCR 2000
