Toro Power Clear 621 - Snowblower Forum : Snow Blower Forums
post #1 of 4 Old 02-07-2020, 05:21 PM Thread Starter
Hello,
I have a Toro Power Clear 621 that I picked up, used, and have a question about it. I don't know how it was treated by the previous owner . . . I have been working to get it in "working order". When I run it, I get oil coming out of the breather tube? What could be causing this? Should the breather tube be connected to something at both ends? Or is one end supposed to be not connected to anything . . . I have the service manual for this snow blower, but it doesn't help!
Thanks,
FredSG
FredSG is offline
post #2 of 4 Old 02-07-2020, 08:42 PM
Motor City's Avatar
Thanks (Received): 54
Likes (Received): 65
First, have you checked the oil, being over filled? If the float sticks open, it will fill the engine with gas. On some engines the breather tube will go to the housing the shield the opening of the carb. Look for a tube, if it has one.
Ariens ST11528LE
Honda HS720
Motor City is offline
Likes RedOctobyr, evh liked this post
post #3 of 4 Old 02-07-2020, 09:18 PM
Thanks (Given): 276
Thanks (Received): 331
Likes (Given): 3366
Likes (Received): 683
Welcome to SBF Fred. It looks like your motor should have a rubber tube going from a nipple on the valve cover to a nipple on the back of the plastic carb\air cleaner cover.
As Motor City said, check your oil level, to full will push oil through the hose and if the oil smells like gas, the inlet needle IN the carb is leaking gas into the motor.
post #4 of 4 Old 02-08-2020, 10:45 AM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Throwing out the welcome mat for your first post.Hearty greetings from the Battlefield of Gettysburg!
Is SG for HD?
2019 Ariens Compact 24...
penna stogey is online now
