Accelerator auger replacement - Snowblower Forum : Snow Blower Forums
post #1 of 2 Old 02-13-2020, 01:49 PM Thread Starter
Hi,
I have a 4 year-old Cub Cadet Snowblower. The accelerator auger is broken. This is the auger that is in front of the other blades and is designed to break up heavier snow/ice. In addition to not being able to figure out how it broke (The shear pin broke too) I can't seem to find any information or tutorials on how to replace it. All the on-line videos concern the impeller and don't mention this part. Help!
Edward Dionne is offline
post #2 of 2 Old 02-13-2020, 03:32 PM
tabora's Avatar
Thanks (Given): 47
Thanks (Received): 248
Likes (Given): 143
Likes (Received): 500
Pull off the CASTER AXLE CAP (13) and then there's a 5/16-18 bolt (7) that holds the HUB CAP WASHER (18) in place. The Accelerator should simply pull off once the shear bolt is removed/broken. May require some twisting/pulling action if the pin didn't shear cleanly.
tabora is online now
