Deere 1028E starting problem - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-16-2020, 12:06 PM Thread Starter
Hello,
I live in Green bay area. I have a 2010 John Deere 1028E. B&S motor. I have had very few problems with it.
The other day I went to start it with the electric start, this is what happened.
Pressed start button, clunk engine did not turn over.
Tried the pull start, stuck could not pull.
Rocked the blower back and forth then was able to pull the recoil.
Used electric start and it fired up.
Blew snow for 30 minutes no problem.
Two days later same scenario.
Today it is fine again.
I would appreciate any help.
Drew747 is offline
post #2 of 10 Old 02-16-2020, 02:01 PM
Thanks (Received): 98
Likes (Received): 260
Maybe ice/snow is freezing up in the impeller housing, and the cable is too tight, so the impeller is engaged and frozen. Just a possible scenario !
RIT333 is online now
Likes Kiss4aFrog, Drew747 liked this post
post #3 of 10 Old 02-16-2020, 02:16 PM
Thanks (Received): 14
Likes (Given): 36
Likes (Received): 28
I would guess ice in the recoil rope housing. Once it warms or gets knocked loose the flywheel can rotate.
oneboltshort is offline
post #4 of 10 Old 02-16-2020, 03:05 PM
Thanks (Given): 590
Likes (Given): 4371
Likes (Received): 1743
to SBF Drew
Did you own this last year, did this happen last year ?
One possibility is something isn't adjusted properly. I would check for proper factory adjustment of the drive and auger cables.
Do you store it outside between uses ?
Likes Drew747 liked this post
post #5 of 10 Old 02-16-2020, 03:41 PM Thread Starter
Thanks for the welcome. I bought it new in 2010. Never happened before. It's stored in a garage that never usually gets below 40 degrees,
although it was quite cold last week about 7 degrees.
Drew747 is offline
post #6 of 10 Old 02-16-2020, 04:09 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post...Hearty welcome from the Burg
2019 Ariens Compact 24...
penna stogey is offline
Thanks Drew747 thanked for this post
post #7 of 10 Old 02-16-2020, 04:31 PM
Likes (Given): 36
If you have an air compressor run the blow gun spout under the shrouding in and around the recoil and electric starter if you get a few puffs of stuffing type crap you might have a nest.
post #8 of 10 Old 02-23-2020, 10:12 AM Thread Starter
Thanks to all that answered. I put the snow blower in my neighbors heated garage for a few days. Then blew out the shroud as suggested. Seems to be ok now.
Drew747 is offline
post #9 of 10 Old 02-23-2020, 10:30 AM
Thanks (Given): 19
Thanks (Received): 99
Likes (Given): 745
Likes (Received): 266
did you evict mini and family ? it's the time of year they tend to build a new home overnight under the tin work
87powershiftx2 is online now
post #10 of 10 Old 02-25-2020, 01:54 PM Thread Starter
There was no crud under the shroud.
Drew747 is offline
