Electrical/stator issue on Briggs snowblower - Snowblower Forum : Snow Blower Forums
post #1 of 8 Old 02-18-2020, 06:06 PM Thread Starter
I have a 2 stage briggs snow blower (Briggs engine) with headlight, heated grips and power chute controls. All worked fine but now I have no power at all. Blower starts fine but I have no voltage coming from the stator wire (single wire with green connector). Not sure if I tested it correctly. I took my multimeter on AC volts, put red lead on wire from stator and grounded the black lead to the engine. Got no voltage reading at all. I removed the stator today to examine it thinking I'd find some obvious burning but stator looks brand new and wire lead has no kinks or cuts. Is there a way to bench test the stator to see if it is good? Ive replaced stators on lawnmowers that were obviously burned up but this one looks perfect. The unit also has a voltage regulator though I have not tested that yet as I wasnt getting voltage going to it from the stator.
Any help is appreciate.
kingcheez is offline
Thanks Fat City thanked for this post
Likes Fat City liked this post
post #2 of 8 Old 02-18-2020, 07:28 PM
Thanks (Given): 231
Thanks (Received): 199
Likes (Given): 2045
Likes (Received): 517
welcome @kingcheez!
year of engine?
How many wires are coming off of your stator?
what color are the wires and connector(s)?
('87 Toro 38150 826)
classiccat is online now
post #3 of 8 Old 02-18-2020, 08:13 PM
Why AC volts, would think that it would be DC voltage???
Johnny G1 is online now
post #4 of 8 Old 02-18-2020, 08:29 PM
Thanks (Given): 231
Likes (Given): 2045
Stators produce alternating current.
Briggs and Stratton will add a single diode to some stator outputs (which blocks the negative half of the sine wave) and calls that mess DC.
Likes Johnny G1 liked this post
post #5 of 8 Old 02-18-2020, 11:25 PM
Thanks (Given): 48
Thanks (Received): 248
Likes (Given): 145
Likes (Received): 501
Look on pages 10 & 16 of the B&S Engine Alternator Repower Guide: https://www.google.com/url?sa=t&rct=...5F0_duuksKI8Sm
Looks like the green connector would indicate 9 or 10 Amps of AC.
tabora is online now
Likes Johnny G1, Fat City liked this post
post #6 of 8 Old 02-19-2020, 02:12 PM
Thanks (Received): 28
Likes (Given): 143
Likes (Received): 57
Throwing out the welcome mat for your first post!!!
Welcome from the Burg!
2019 Ariens Compact 24...
penna stogey is online now
post #7 of 8 Old 02-19-2020, 08:04 PM
Likes (Received): 22
Look very close for ANY corrosion. I have had Kohler stators with just a green dot that was a wire broken by corrosion, that's all it takes.
If I can't fix it, I can screw it up so bad that no one else can either!
Greg13 is offline
post #8 of 8 Old 02-19-2020, 10:19 PM
Thanks (Given): 197
Likes (Given): 197
Likes (Received): 10
I test stators with a tractor headlight [ old school filament style ] which will light if either AC or DC is present when engine is running .
Fat City is offline
