Husqvarna 227 Starting Issues - Snowblower Forum : Snow Blower Forums
post #1 of 20 Old 02-19-2020, 03:52 PM Thread Starter
Hi folks. My two year old Husqvarna died on me a few weeks ago half way through doing the driveway. I could not get it going again. I pulled the float bowl off and there was some gunk in it, so I proceeded to take the jets out and clean them. Long story short, I'm an idiot and managed to strip the threads for the bolt that holds the float bowl on, so I bought a new carb (oem). I installed it last night and it started no problem, but it ran horribly with the choke on. When the choke was put in 'run' it worked perfectly.
Today it will not start at all. It backfires through the exhaust, and also through the float bowl. The smoke is black. Does anyone have any idea what this could be? Below is a video. Thanks everyone!
https://youtu.be/Hc4bZQdM-7w
Ditto110 is offline
Thanks Fat City thanked for this post
Likes Fat City liked this post
post #2 of 20 Old 02-19-2020, 04:50 PM Thread Starter
As a follow up... it does not actually run perfect in 'run'. I finally got it going a few minutes ago. Crazy amounts of smoke, and then it died after 30 or 40 seconds. This happened twice.
Ditto110 is offline
post #3 of 20 Old 02-19-2020, 04:53 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 252
Chinese junk carburetor? Sounds like it is running massively rich, choke on or not . . .
tadawson is offline
post #4 of 20 Old 02-19-2020, 05:35 PM
Thanks (Received): 11
Likes (Given): 28
Likes (Received): 32
You shouldn't need the choke "on" for the engine to run...it should run in the "run" position, unless I am missing something.
I'm going to ask a dumb question, but did you remember to turn the gas valve back on after you replaced the carb? And is there gas in the tank?
Its hard for me to tell on the video what it sounds like, When I get home I can try to give it a listen.
2muchsnow is online now
post #5 of 20 Old 02-19-2020, 06:44 PM Thread Starter
Fuel is on. Tank is full of fresh gas. Occasionally it will give some pretty loud backfires through the exhaust, with the occasional flame.
Ditto110 is offline
post #6 of 20 Old 02-19-2020, 06:59 PM
Likes (Given): 28
How does the spark plug look?
Sent from my Pixel 4 XL using Tapatalk
Likes Fat City, 87powershiftx2 liked this post
post #7 of 20 Old 02-19-2020, 07:01 PM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post..Greetings..
2019 Ariens Compact 24...
penna stogey is offline
post #8 of 20 Old 02-19-2020, 07:07 PM Thread Starter
Thanks, penna!
Plug is brand new with an NGK one I got from the dealer.
Thanks for the responses to everyone so far, I do appreciate it !
Ditto110 is offline
post #9 of 20 Old 02-19-2020, 08:29 PM
Likes (Given): 28
Any chance something got in your air intake?
post #10 of 20 Old 02-19-2020, 10:13 PM
Thanks (Given): 197
Likes (Given): 197
Likes (Received): 10
My guess is the carb is ' over floating.' Check [ smell ] the oil for fuel dilution . Shut off gas, remove float bowl . Drain gas from bowl . Replace bowl , turn on gas for a minute . Shut off gas, put container under carb, and remove float bowl again. Now put your thumb over hole in bowl, pour drained off gas back in bowl , observe fuel level in bowl , should be about 1/2 full
Fat City is offline
