Auger belt vibration and broken mystery spring - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 02-22-2020, 04:45 PM Thread Starter
Question Auger belt vibration and broken mystery spring
I have a Yard Machines 30" snowblower purchased new 2 years ago (2018). Its been working fine until the last few snowstorms when I began to notice some play in the auger control cable connecting the auger hand lever to the auger engagement wheel inside the machine. This loose cable issue seems to be correspond to a noticeable 'banging' noise whenever I depressed the auger lever on the handlebar. Additionally I was seeing that auger continues to spin even when the handle is not engaged.
At first I assumed the cable had been stretched and needed to be replaced (the tension adjustment had already been maxed out). I ordered a new one and installed it. While the cable is a bit more taunt now, the banging continues whenever I press down on the auger lever. However this time because I had the flywheel cover off (to replace the cable) I can now see that there is a noticeable vibration in the belt when the auger is engaged.
So I investigated further and separated the auger section from the rest of the snowblower. When looked inside the space at the bottom of the snowblower chassis I could see a loose spring sitting there. One end was fine and still had its 'hook' but the other end had been broken and its hook was gone. I've included some pictures to better explain what the spring looks like and where it was found. Question is: what does this spring attach to? And could the fact its broken be the cause of the vibration I'm now seeing? Any suggestions are appreciated.
ID:	164179   Click image for larger version
ID:	164181   Click image for larger version
ID:	164183   Click image for larger version
gatmando is offline
post #2 of 10 Old 02-22-2020, 06:09 PM
Thanks (Received): 14
Likes (Received): 80
Been a long time since I have been in one and they all are a bit different, so this is just a general take.
Its a tension spring of course, if you look to the left you see another one and its (call it the far end) is hooking to the housing.
Clearly the one in hand is intended to be at roughly the angle you have it roughly, so you look for a two hole setup or tab like the other one has.
1998 YT624 Have Owners and Service Manual, Rubber Disc Drive (not hydrostatic)
RC20 is offline
post #3 of 10 Old 02-23-2020, 03:11 AM
Thanks (Received): 25
Likes (Given): 107
Likes (Received): 65
If the auger is still spinning then check to see if there's a brake that's not working while you're in there. It is something that presses against the bottom pulley when you release the handle. Spring might be to that or to pull the engagement lever away to release belt tension.
Take a picture of the blower pulley/bucket end, spring probably goes on that side.
notabiker is offline
Likes oneboltshort liked this post
post #4 of 10 Old 02-23-2020, 05:52 AM
Thanks (Received): 28
Likes (Given): 142
Likes (Received): 57
Throwing out the welcome mat for your first post...Greetings from Gettysburg
2019 Ariens Compact 24...
penna stogey is offline
post #5 of 10 Old 02-23-2020, 06:43 AM
Thanks (Received): 99
Likes (Given): 741
Likes (Received): 263
welcome to snow blower forums gatmando
help us a little more by supplying the model number off the machine from there many of us can help dig up the shop manual for more help
87powershiftx2 is offline
post #6 of 10 Old 02-23-2020, 08:26 AM
Likes (Given): 36
Likes (Received): 28
oneboltshort is offline
Likes Shovel liked this post
post #7 of 10 Old 02-23-2020, 12:50 PM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 235
Likes (Given): 1582
Likes (Received): 1671
since you have the bucket off , inspect/replace impeller bearing and belt if needed.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #8 of 10 Old 02-23-2020, 12:55 PM Thread Starter
That was my main focus when I found the sprint - it seemed like it might belong on the opposite side of the spring that's still in place in the photo. But while the in-place spring on the left had obvious holes for hooking the spring there was no equivalent on the other side (as far as I could see).
gatmando is offline
post #9 of 10 Old 02-23-2020, 12:57 PM Thread Starter
Thanks for the welcome!
gatmando is offline
Likes penna stogey liked this post
post #10 of 10 Old 02-23-2020, 01:02 PM Thread Starter
Originally Posted by oneboltshort View Post
Ah! I didn't even think to look at the auger/impeller side when I had the snowblower separated. If that spring is part of the auger-engagement system that would certainly explain some of the issues. I'll have a look and reply when I've had a chance to look (might be a few days due to work).
gatmando is offline
