Idle rod ??? - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 03-06-2020, 09:35 PM Thread Starter
Idle rod ???
So the rod that goes in the image I attached broke so I have a replacement rod but not sure what hole it goes into ,the machine is a murray 8/24 model 624808x31e
carp130 is offline
post #2 of 6 Old 03-06-2020, 09:56 PM
Thanks (Received): 14
Likes (Given): 36
Likes (Received): 28
oneboltshort is online now
post #3 of 6 Old 03-06-2020, 09:59 PM Thread Starter
👍 thanks
carp130 is offline
post #4 of 6 Old 03-07-2020, 05:35 AM
Thanks (Received): 150
Likes (Received): 543
Its usually in the center one.
oneacer is offline
post #5 of 6 Old 03-07-2020, 07:41 AM
Thanks (Given): 172
Thanks (Received): 338
Likes (Given): 477
Likes (Received): 837
I'd also look for shiny spots in/around the different holes, as a double-check. The hole that's shiny on the inside diameter surface is likely the one you've been using.
Likes aldfam4, Kiss4aFrog liked this post
post #6 of 6 Old 03-07-2020, 09:48 PM
Thanks (Given): 590
Likes (Given): 4368
Likes (Received): 1742
It looks like the one hole is well worn. Might be the camera angle too but if you can see the hole is worn as it appears in the photo that's the hole the rod goes in.
