Snowblower run rough or stalls when temp is hot - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 03-12-2020, 08:32 PM Thread Starter
Hi guys,
When itís cold out, (-20 celcius and colder )the engine runs well and strong but when its hotter like -5 celcius or hotter, it first start well but when it get to operating temp, it start to run rough. When it stalls ( which happen alot), one or two push of the primer bulb starts right up. So it basicly starving fuel. If i let it cool down, it will run well for 5 mins and the issu will come back. I was thinking of trying a colder plug ? Your thoughts? What should i check next? I have a mastercraft 30Ē 10.5 hp tecumseh engine.
Dannyrsnowblower is offline
post #2 of 7 Old 03-12-2020, 08:46 PM
Thanks (Given): 95
Likes (Given): 75
Likes (Received): 457
I think it's a dirty carburetor, ........., inlet float valve, not likely it's the spark plug but cheap enough.
post #3 of 7 Old Yesterday, 01:20 AM
ST1100A's Avatar
Thanks (Given): 198
Thanks (Received): 124
Likes (Given): 398
Likes (Received): 261
It sounds like the float level might be out of adjustment, like the level is too low.
Most cases the float seat would have to be replaced because they "Swell" and that drops the float level so you don't have enough fuel in the Carburetor bowl to meet the engines fuel demands and it cant replenish itself fast enough.
Many times when that happens you will get a surging engine speed before it gets too bad and dies all together, then it has to be re-started, and usually when it gets like that, by the time it stalls and you go to re-start it, the fuel level has enough time to replenish itself in the bowl.
ST1100A is offline
post #4 of 7 Old Yesterday, 11:10 AM
ST1100A's Avatar
Thanks (Given): 198
Likes (Given): 398
One thing I forgot to mention, check your valve clearance in case you have a tight valve. Once it warms up, it will lose clearance and may not close tight enough to seal properly and need to be re-adjusted to seal better when the engine gets hotter.
ST1100A is offline
post #5 of 7 Old Yesterday, 01:10 PM
Thanks (Received): 95
Likes (Given): 695
Likes (Received): 244
op states old tech engine
sounds like poor fuel flow
is the bowl on in the right spot, wrong side improper float drop level?,is the needle stinking in the rubber seat? might be time for a new carb,
is the gas cap vent hole plugged from a mud dabber? builds up vacuum stops, sits flow slowly returns it runs ,repeats.
sounds like something simple stupid will be found
87powershiftx2 is offline
Likes ST1100A liked this post
post #6 of 7 Old Yesterday, 03:14 PM
Thanks (Given): 95
Likes (Given): 75
Good catch 87Powershiftx2.
Take the gas cap off and see if you have a problem. Put a piece of aluminum foil in its place with a small hole in the middle then see.
post #7 of 7 Old Yesterday, 06:46 PM
Thanks (Received): 15
Likes (Received): 59
I vote for the fuel cap not venting. This will result in impaired fuel flow and the engine eventually stalls. Solution: a new fuel cap or a TINY hole in your current cap.
CO Snow is online now
Likes tuffnell liked this post
