Dirty carb? Try these tips - Snowblower Forum : Snow Blower Forums
post #1 of 11 Old 03-14-2020, 09:15 AM Thread Starter
Thanks (Given): 96
Likes (Given): 75
Likes (Received): 459
Dirty carb, Rough running, AND you don't want to remove the carb! With some Chinese engines it can be time consuming and a nuisance.
Remove the bowl, clean with a rag
Remove any accessible jets
Spray carb cleaner using the little red blow tube that comes with the can of carb cleaner in the jet holes and in the holes where the jet came out of. Spray the carb cleaner up in the main jet tube that is located inside the fuel bowl.
Put it back together
Snap your fingers
Start it
I've have had success with some snow blowers just removing the bowl and spraying up the main jet.
Check the clarity of the gas by draining some in to a clear soda bottle to ensure it's fresh. Do not trust the home owner!!! It may be fresh but the gas can could have had old gas in it, adding fresh gas may not be enough; the same for adding fresh gas to the gas tank when it's had old gas in it or its been sitting for too long.
JLawrence08648 is offline
Likes Ziggy65 liked this post
post #2 of 11 Old 03-14-2020, 10:08 AM
orangputeh's Avatar
Thanks (Given): 762
Thanks (Received): 234
Likes (Given): 1574
Likes (Received): 1636
Snap your fingers
Start it
90 % of the Honda carb cleaning I do is done successfully in frame. I also remove airbox and spray thru all holes and remove the idle jet and clean. replace that little O ring if necessary.
usually spraying up the pick up tube is enough depending how dirty it was when I removed bowl. In some cases I remove the main jet and emulsion tube.
Then follow up and dry with compressed air.
This works about 90% of the time and usually takes only about 20 minutes with a Honda Carb. In the other 10% stubborn carbs need to be removed and placed in the ultrasonic cleaner.
"It Feels Like Beer O'Clock "
orangputeh is online now
post #3 of 11 Old 03-14-2020, 10:19 AM Thread Starter
Thanks (Given): 96
Likes (Given): 75
Ah, I forgot the compressed air, works really well. Loosen up the crap with the carb cleaner then blow it away with the compressed air, may have to do it a few times waiting a bit between carb sprays, but certainly the simplest way. Puts a smile on your face if it works. Makes you feel like a genius and impresses the customer that you know exactly what to do.
post #4 of 11 Old 03-14-2020, 01:19 PM
orangputeh's Avatar
Thanks (Given): 762
Likes (Given): 1574
it's funny you mention that it makes you feel smart. EVERY time I start an engine after a carb cleaning I cross my fingers and wait.......when it runs right I am surprised.."I did it?"
and then people think you are a magic man cause they brought the machine over thinking it was a lost cause and you got it started and running like new . the word get's around.
I get calls from people and the first thing they say " I heard you're the man when it comes to Honda's.
makes you feel good.
I always considered you the guy when it comes to cleaning carburetors. learned a lot from you here.
Thanks.
Thanks JLawrence08648 thanked for this post
Likes RedOctobyr, JamesReady, 88-tek liked this post
post #5 of 11 Old 03-14-2020, 01:53 PM
Thanks (Given): 17
Thanks (Received): 7
Likes (Given): 12
Likes (Received): 22
Dirty plugged up carbs..been a long winter of them, and now we move into the "spring/summer" machines people have.
What is even worse is when you clean a carb and get the machine running, only to have the same person bring it back 2 months later for the same issue...ah but they know we can fix it.
Newer carbs are in some ways easier to clean..the older Tecumseh ones seem to get plugged in two or three areas.
Ethanol fuel, a love/hate relationship, and one of the biggest repeat business customer creators out there.
BTW, I do suggest where to purchase non ethanol fuel to all of my customers, and fill their machine with a fresh tank of fuel when I service it..many just comment..."I know, and then say it is just good to have their snow blower back."
3vanman is offline
post #6 of 11 Old 03-14-2020, 03:37 PM Thread Starter
Thanks (Given): 96
Likes (Given): 75
When someone drops off equipment, I emphasize to bring me their gas can, whether they say it's empty or not. The gas in the gas can tells a lot. I tell them I will look at it or empty it and fill it with fresh gas, fuel stabilizer, and a fuel cleaner. I want to make sure you start right.
Likes 3vanman liked this post
post #7 of 11 Old 03-14-2020, 09:11 PM
Thanks (Received): 80
Likes (Given): 75
Likes (Received): 276
i use compressed air most of the time. if compresses air doesn't work to clean out any blocked or clogged passages you likely need to remove and possibly replace the carb at that point. sometimes i will use oven cleaner but that also usually removes any protective coating from anything so got to be careful when using it but it does clean almost anything.
yardworks 31AH6WKF515
crazzywolfie is online now
post #8 of 11 Old 03-15-2020, 03:11 AM
ST1100A's Avatar
Thanks (Given): 199
Thanks (Received): 125
Likes (Given): 402
Likes (Received): 265
Your oven cleaner works good on baked on carbon deposits on things like piston heads, cylinder heads, valve faces and stems plus intake and exhaust ports.
I would be leary about using it on carburetors and their parts, like you mentioned, it will remove any protective coatings on them and make them corrode in time.
It also helps break down grease and oil build-up.
ST1100A is offline
post #9 of 11 Old 03-15-2020, 08:09 AM
Likes (Given): 75
if your going to have to replace the carb anyways what do you have to loose trying oven cleaner? i know it works good for cleaning rest of the engine parts way more effectively than most products. i usually use it cleaning intake manifolds which can be pretty stubborn.
Likes ST1100A liked this post
post #10 of 11 Old 03-15-2020, 11:10 PM
Thanks (Given): 26
Likes (Given): 85
Likes (Received): 249
Uh, everything? Most oven cleaner is caustic, and really tears up aluminum. Myself, I'd try pretty much anything else first, no matter what the status of the carb . . .
tadawson is offline
Likes JamesReady liked this post
