1976 Montgomery ward snow blower won't start - Snowblower Forum : Snow Blower Forums
post #1 of 5 Old 09-17-2014, 09:06 PM Thread Starter
Angry 1976 Montgomery ward snow blower won't start
Hi guys I just got done restoring a 1976 2 stage Montgomery ward snowblower it ran great when I got it but it desperately needed a paint job so I painted it. And now all of the sudden it won't run at all I need help
Any info would be helpful
Zack
Hibmazackery is offline
post #2 of 5 Old 09-18-2014, 11:48 AM
Thanks (Received): 17
Likes (Received): 79
either the carburetor is blocked with dirt in the idle circuit, or the points closed up on it and there's no spark.
other problems but less common are bad coil, or blocked fuel line
it can also be something as simple as a bad spark plug.
very rarely do the Briggs have any other problem than that, if they are worn out they usually still run but may smoke or make noise.
pull the spark plug, clean it, and lay it on the engine. put the throttle in run, and pull it one time, the spark plug should spark. make sure it's not above the spark plug hole in the block so gas doesn't come outside the engine and ignite in the air. if it has spark, move on.
make sure the kill switch wire lead is not grounded out, or that some other wire is not grounded out.
if you have spark, spray some gas into the carburetor throat with a spray bottle, or starting fluid, close the choke completely and see if it starts. if it does, the carb needs to be cleaned out.
also check fuel filter make sure it's not plugged, and fuel tank petcock make sure it's not blocked or shut off. if the gas has been sitting a long time, old gasoline will give starting problems too
check for gas, spark and report back
1967 S-242 Snowbird 4/24
Gilson 55012 8/26 gear drive
Ariens 910010 8/32
Cub Cadet 268 8/26
Yard-Man Snowbird 7040-0 5/22
Ariens 10M-L35 3.5/24
greatwhitebuffalo is offline
post #3 of 5 Old 09-18-2014, 02:10 PM
Thanks (Received): 372
Likes (Received): 1318
YEAHHHHHHHHHHHHHH what he just said. ALOHA to the forms..: cool:
post #4 of 5 Old 09-18-2014, 09:21 PM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
Zack
Are you lacking spark? If so and assuming you didn't do much with the engine I'd suspect the interlock system. If you disconnect the kill wire from the handle does the engine have spark?
Pete
Spectrum is offline
post #5 of 5 Old 09-19-2014, 08:40 AM
Thanks (Given): 167
Thanks (Received): 301
Likes (Given): 411
Likes (Received): 1001
Make sure your key is on. Follow what Spectrum said.
Welcome to the forum.
