Tecumseh 8hp carburator leaking fuel. - Snowblower Forum : Snow Blower Forums
post #1 of 6 Old 09-29-2014, 01:32 PM Thread Starter
First I thought it was the float bowl gasket, replaced that and now it looks like fuel is leaking out from above it, where the choke is. Raising the float does completely shut off fuel flow. Not sure what the problem is.
My guess is that the fuel float is sticking? Should I spray it all down with carb cleaner? Any other problems it could be?
Jdam00 is offline
post #2 of 6 Old 09-29-2014, 01:42 PM
CarlB's Avatar
Thanks (Received): 33
Likes (Received): 78
take the float out and shake it. It may have a leak and has fuel in it. If so it will not rise enough to stop the fuel flow. If it doesn't have a leak it may need to be adjusted. If i remember correctly with the carb upside down there should be an 1/8" gap between the float and the carb body. you can use a 1/8" drill bit to check it. carl.
CarlB is online now
post #3 of 6 Old 09-29-2014, 05:42 PM
94EG8's Avatar
Thanks (Received): 48
It's bigger than an 1/8th. 17/64ths I think. It's been a while. The float should be more or less level when the needle valve is seated.
Check to see if the float is leaking and replace the needle and seat (small carb kit with the needle, seat and fiber washer is $10.00 over here in Canada, it should be less in the US.
94EG8 is offline
post #4 of 6 Old 10-01-2014, 07:21 PM Thread Starter
Had the carburetor rebuilt. Purring like a kitten. It's my first snowblower, and I have a miserable driveway. I have never been so excited for winter in my life. Bring it on!!
Jdam00 is offline
post #5 of 6 Old 10-02-2014, 12:38 PM
SlowRider22's Avatar
Likes (Received): 12
Did you rebuild the carb or did you have a shop rebuild it for you?
1971 Ariens 7/24 (retired)
2011 Ariens Deluxe 24
1980 Ariens st7/24 (retired)
1985 Ariens st10/36
SlowRider22 is offline
post #6 of 6 Old 10-10-2014, 06:23 PM
Likes (Received): 39
I remember being excited for winter... I hear it's going to be a doozy here in New England again.
nt40lanman is offline
