Starter drive gear on my TORO CCR3650 GTS ?? - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-07-2014, 11:15 PM Thread Starter
Question Starter drive gear on my TORO CCR3650 GTS ??
Hello everyone,
New here...Seems like a nice forum so turned here for help.
Just bought a 10 yr old Toro 3650, PO said Elec start wasn't working and he didn't bother fixing due to cost, I opened up and see that the plastic post is broken on one side. I put Quiksteel and secured it. The drive gear shows some wear/1 teeth broken. I filed a tiny bit to make all teeth straight as they all were slightly leaned. Upon cranking I hear heavy grind. I didn't go more than 2 secs. STARTS IN 1 PULL. I wonder if I should change the drive gear. I took a look at the flywheel AGAIN the gears seem fine, but how to make sure its not bad.? Thanks folks.
torortek is offline
post #2 of 10 Old 10-08-2014, 03:40 AM
Thanks (Received): 372
Likes (Received): 1316
the starter motor is on it's last leg. you will have to get a new one. ALOHA to the forms..: cool::co ol:
post #3 of 10 Old 10-08-2014, 06:00 AM
Thanks (Given): 221
Thanks (Received): 294
Likes (Given): 1802
Likes (Received): 623
hello torortek, welcome to SBF!! its time to decide if you want to replace the starter or just pull start it like the po was doing. if its just the starter gear those things are plastic and can be replaced without replacing the starter motor
post #4 of 10 Old 10-08-2014, 06:55 AM
94EG8's Avatar
Thanks (Received): 48
Tecumseh starters use a metal gear. The late model units were notorious for breaking teeth off, these will have a blue tinge to them.
Remove the flywheel and see if the missing tooth is stuck to the magnet on the flywheel. Sometimes they'll get jammed between the magnet and the stator ripping the stator off the block mounting bosses and all draining all the oil and then the engine throws a rod. Put everything back together. Replace the starter. Chances are the mounting tabs are bent and/or broken and it's not engaging correctly.
94EG8 is offline
post #5 of 10 Old 10-08-2014, 11:22 AM
Likes (Received): 303
I think the 3650 has the R-Tek which was a Briggs engine. You can go to toro.com, select the "parts" tab at top, put in model as 38517 and then find your serial number range (sticker on lower back, or side of blower) it will bring up schematics that at least give you some idea of what parts should be there.
post #6 of 10 Old 10-08-2014, 10:06 PM Thread Starter
Thanks for all inputs folks. If a broken tooth is struck in..wont it make constant noise while engine running. Will try to open up & inspect.
torortek is offline
post #7 of 10 Old 10-08-2014, 10:54 PM
Grunt's Avatar
Thanks (Given): 259
Thanks (Received): 319
Likes (Given): 3148
Likes (Received): 629
If the tooth is stuck in the flywheel, highly unlikely, it will not make any noise since the starter gear is the only part that touches the flywheel teeth.
post #8 of 10 Old 10-08-2014, 10:59 PM
He got rid of a snow blower because the electric start didn't work, but it starts on one pull? That's somewhat goofy!
Blaine B. is offline
post #9 of 10 Old 10-09-2014, 12:38 PM Thread Starter
I knw what youre thinking !!
PO had starting issues due to plugged carb in the past i suppose, hence he had shown his frustration to the starter..LOL. But now that the carb is clean..starts like it shld..i swear i dont even pull hard and it starts in 1 pull. THESE ARE GREAT MACHINES ~ I LOVE THEM ~ MORE THAN MY MOTORCYCLES ~ OK I TAKE BACK.
torortek is offline
post #10 of 10 Old 10-09-2014, 02:29 PM
Yeah, I don't bat an eye when someone wants to get rid of something cheap for a ridiculous issue. But I can't help but feel somewhat funny inside. But that feeling disappears quickly, because after all, we're not forcing them to sell, nor are we stealing from them.
Good for you an me in that case There must always be winners and losers.
