Toro broken plastic housing repair - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 10-18-2014, 01:33 PM Thread Starter
I picked up a decent running Toro S-620 that has a crack in the plastic housing behind the scraper bar. In addition to the crack there is a piece broken from the front middle edge of that same surface about the size of a match book. I didn't see any of this and now wonder if the unit is serviceable. I originally thought about sheet metal but thought I'd pick the forums brain first. Any thoughts???
Carpe diem; this isn't a dress rehearsal
Cub Cadet QA36A (been on 3 different tractors)
1987 Toro 826
1981 Toro S140
1990 Toro S-620
1979 toro S-200
Prometheus is offline
post #2 of 10 Old 10-18-2014, 01:37 PM
I would think either bolt sheet metal too it or try plastic welding it with a soldering iron. You could try some epoxy too.
https://www.youtube.com/user/sixtyfi...?query=plastic
I fixed the plastic around the wheelwells and front spoiler on a car with pieces of an old plastic tote and some pop rivets.
post #3 of 10 Old 10-18-2014, 01:41 PM
Bob E's Avatar
Thanks (Received): 19
Likes (Given): 77
Likes (Received): 34
Sheet metal and rivets would probably be my choice.
Bob E is offline
post #4 of 10 Old 10-18-2014, 01:46 PM
Thanks (Given): 135
Thanks (Received): 267
Likes (Given): 358
Likes (Received): 903
Epoxy and fabric. Lowes carries it.
micah68kj is offline
post #5 of 10 Old 10-18-2014, 02:18 PM Thread Starter
Do you guys think that epoxy or fiberglass would survive the vibration? This thing starts great (noisy as sin) and I'd hate to just tear it down for the parts.
1987 Toro 826
1981 Toro S140
1990 Toro S-620
1979 toro S-200
post #6 of 10 Old 10-18-2014, 05:35 PM
Likes (Given): 1633
Likes (Received): 571
I had a ccr 2000 with a hole in the front cover. I use sheet metal and self tapping screws seeing that's what I had at the house. eventually I found a good cover and replaced the broken one
post #7 of 10 Old 10-18-2014, 06:28 PM
Bob E's Avatar
Likes (Given): 77
I'm not sure epoxy would do the trick by itself without something else added for reinforcement.
If you encased the whole area with fiberglass I doubt vibration would be a problem, but I'm not sure if it would wear differently than the plastic. Also make sure you don't build it up too much causing clearance issues.
Aluminum sheet and rivets have worked really well on my lawn tractors broken gill.
ID:	23113   Click image for larger version
Bob E is offline
post #8 of 10 Old 10-18-2014, 07:37 PM
Grunt's Avatar
Thanks (Given): 236
Thanks (Received): 276
Likes (Given): 2803
Likes (Received): 506
Could you post some pictures of the damaged area?
Toro 421-QZE (38585) 2008 (Gone)
Toro 721-QZR (38741) 2015 (Hemi Predator Power)
post #9 of 10 Old 10-18-2014, 08:42 PM Thread Starter
I'll try to get some pictures of the damaged area tomorrow. You guys have got me thinking and the creative juices are flowing. Thanks so far for the input.
1987 Toro 826
1981 Toro S140
1990 Toro S-620
1979 toro S-200
post #10 of 10 Old 10-21-2014, 07:03 PM
I cut two pieces of flashing twice the size of the area to cover and folded them in half and beat the seam down flat. I put a piece on both sides with machine screws after filling the broken area with JB Weld. I am not a big epoxy fan or JB weld but it worked.
countryboymo is offline
