8hp tec surging\hunting even afte rebuild?? - Snowblower Forum : Snow Blower Forums
post #1 of 27 Old 10-19-2014, 10:04 PM Thread Starter
i just bought this snowblower 8hp with series 3 carb tecumseh craftsman
this part that im also concerned with is pull cord is sometimes hard to pull and kicksback???
i soaked the carb overnight in methyl hydrate and then cleaned it with carb cleaner. and changed seat, float, bowl, needle and bowl gasket. i even changed the gasket between the carb and intake pipe
Motor is still hunting tho??
wantboost is offline
post #2 of 27 Old 10-19-2014, 11:01 PM
Snapper 524's Avatar
Likes (Given): 7
Likes (Received): 9
Does this help?
Snapper 524 is offline
post #3 of 27 Old 10-19-2014, 11:24 PM Thread Starter
no mine is adjustable. i just edited my post that i have a series 3 carb
post #4 of 27 Old 10-19-2014, 11:35 PM
Motor City's Avatar
Thanks (Received): 48
Likes (Received): 52
If its still hunting, did you play with the governor at all? If not, the carb is still not clean, enough. On the kickback, you may want to check the flywheel key. It might be partially sheared.
Ariens ST11528LE
Honda HS720
Motor City is offline
post #5 of 27 Old 10-19-2014, 11:39 PM Thread Starter
Previous owner might of touched govenor screw as I noticed he had idle screw all the way in. What should i do with governor screw? How do I check flywheel key
post #6 of 27 Old 10-19-2014, 11:47 PM
Likes (Given): 7
Likes (Received): 9
post #7 of 27 Old 10-20-2014, 12:44 AM Thread Starter
How do I check flywheel key? im starting to think its a timing issues since pull cord is hard to pull. also isnt thing ignition timing also that can be checked?
post #8 of 27 Old 10-20-2014, 12:55 AM
You have to take the flywheel off to check the key.
post #9 of 27 Old 10-20-2014, 09:21 AM
Motor City's Avatar
Some times you can see the key is partially sheared by just removing the flywheel nut. Otherwise as stated above, the flywheel will have to come off. Its not a big job.
Ariens ST11528LE
Honda HS720
post #10 of 27 Old 10-21-2014, 01:37 AM Thread Starter
is that behind the pull cord cover?
