ariens 6hp broken flywheel key - Snowblower Forum : Snow Blower Forums
post #1 of 15 Old 10-27-2014, 08:01 PM Thread Starter
Question ariens 6hp broken flywheel key
Hello
I just bought my first snowblower !
Its an ariens 6hp (1971 i believe).If im right it has a tecumseh h60 engine.
Its in very good condition (not rusted, every major component in good shape.
I broke the flywheel key and cant identify it. And i only have the upper half ! The half that was stuck in the engine shaft flew off when i hit it with a screwdriver and hammer.
I have the repair manual but cant seem to find the part number.
On the snowblower it says model 910006
On the carb it says 116 2f20
On the magneto cover it says 30550 ezee start.
I found the belt number (72047) (its all cracked up)
The shear bolt (10195) always good to have spares i heard
The carb kit (31840) (probably would be good to put fresh parts in there and its only 20$).
I would really appreciate finding the flywheel key ...
old_el_paseo is offline
post #2 of 15 Old 10-27-2014, 08:09 PM
Ray 1962 10ML60's Avatar
Thanks (Given): 24
Thanks (Received): 34
Likes (Given): 15
Likes (Received): 23
I know at my local hardware store they have a little box of woodruff keys, or flywheel keys. I had a similar issue with a lawn mower once and brought the piece with me to match up. I had to grind it down a little when I got home to make it exactly right, but any good hardware store should be able to help you. Not Home Depot or lowes...
What are the engine numbers? H60 ????? ???? Will be stamped in the sheet metal usually on top of the shroud.
Ray
1962 Ariens 10ML60
1979 Toro 524
1975 MTD Snowflite 4/22
Ray 1962 10ML60 is offline
Thanks guilateen02 thanked for this post
Likes guilateen02 liked this post
post #3 of 15 Old 10-27-2014, 08:49 PM
post #4 of 15 Old 10-27-2014, 08:59 PM
Thanks (Given): 522
Thanks (Received): 691
Likes (Given): 3912
Likes (Received): 1505
Welcome to the forum Old El Paseo
Depending on what's around you Orielly Auto Parts might be able to order one for you.
List: Search for '7-03328' | O'Reilly Auto Parts
It crosses over from the #32589 if that one is correct for your engine.
post #5 of 15 Old 10-27-2014, 09:14 PM
Thanks (Given): 522
Likes (Given): 3912
You might want to add your location to your profile as being out of the "states" will make a difference in some suggestions.
post #6 of 15 Old 10-27-2014, 09:17 PM Thread Starter
Actually it's the flywheel key on the ignition side. It's a kind of "trapesium shape".
I think that that one (32589) is on the other side where the blades attach ?
post #7 of 15 Old 10-27-2014, 09:25 PM Thread Starter
There ! I changed my location and added some info about me, thanks for the tip !
post #8 of 15 Old 10-27-2014, 09:32 PM
Thanks (Given): 522
Likes (Given): 3912
No problem, just saw that you are Canadian and that shoots the "Oreilly" recommendation all to heck.
Plenty of suppliers on Ebay and Amazon plus hardware stores so once you ID it should be pretty easy to source one. Might even try a small engine shop to see if they have one on hand (freebie ?).
post #9 of 15 Old 10-27-2014, 09:51 PM Thread Starter
Yeah. Ill try to find a small engine shop near my home. Im looking up everywhere and im starting to think it wasnt the right key in there... Maybe the old owner made himself one.
Seems oem one for mine is part #30884. Ill post back here when i find out.
Thanks for the help !
post #10 of 15 Old 10-27-2014, 09:52 PM
Are you sure it broke? They are usually pretty sturdy. I have never seen one break from being knocked out. Sometimes they have unusual shapes and look stepped.
