Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools |
Toro On/Off Key Operation
Toro 824 Powershift - blower runs great but the key on the control panel doesn't function as it should. In either the on or off position, the machine still runs.
What's the premise on how these operate as a kill switch? There are two wires coming out of the switch that both go to a metal tab that is attached (grounded) on the recoil housing, and the ground wire from the ignition coil also attaches there. My electrician father took a look at it over the weekend and even he couldn't figure out how it isn't grounded 100% of the time.
We at least tested the switch with a DVM and it registered infinite ohms on both on and off. We got the same reading when testing the two wires that connect to the on/off switch. I think we were expecting to see 0 ohms because it would have been a completed circuit.
I would like to have the switch working as it's convenient to turn off the machine with it. How do I go about testing the system and determining if it's all hooked up correctly? Thanks.
Sponsored Links | |||
Advertisement |
Normally when you remove the key it grounds the ignition and stops the engine, so one wire is from the ignition and the other to a ground.
Can you not as well shut the engine when you close your throttle completely? This what most people use to shut the engine or an engine off/on switch.
You should verify if the two metallic tabs have a good contact together when the key is removed which is when you can use your ohm meter to see if there is continuity from ignition wire to engine ground.
The plastic key is meant to shut the engine in an emergency and or preventing the young ones starting the engine inadvertently which is less prone to happen. I never use the plastic key to shut my engine as it is prone to break in half and the throttle is easier to use. Just my opinion.
Snow Removal Apparatus I own:
by Princess Auto in Canada.
Those key switches if using a metal key have a tendency to corrode internally from water entering the key slot. One wire will go to ground, such as a ring terminal on the recoil housing. The second wire will go to a nylon or plastic insulated block on the recoil that connects to the ignition coil kill terminal and is isolated from ground.
Yea, pretty simple. One wire comes from the ignition and goes to the switch. The other wire goes back to touch the engine. When the switch is "off" those 2 wires are touching which causes the spark to ground out on the engine instead of sparking at the plug. When the switch is "on" it causes a break in that wire which lets the engine run. Either one of your wires is broken / disconnected or your switch is worn out.
Thanks Grunt for clearing this up for me as I thought they were all metal tabs where the key is inserted.
Originally Posted by Normex
View Post
Originally Posted by Grunt
View Post
Quick edit: both of the wires from the switch are attached to a grounding tab located on the recoil housing, along with the wire that comes from the coil. Should it actually be that the coil ground wire should just be attached to one of the wires from the switch and not also screwed onto the grounding tab? Would the switch work then?
Originally Posted by threeputtpar
View Post
So for testing purposes on the key cylinder, when in the off position a DVM should read 0 as it's making a circuit and in the on position it should read ??? because the circuit is broken allowing the coil to fire? Do I have that right, and if the meter shows ??? that means the cylinder is bad?
If the key cylinder is the culprit, wouldn't it be more likely that it would have failed in the off mode making it impossible to start the engine? I'd think that it would be engineered to be a failsafe and not a fail runaway engine.
View Post
Advertisement |
Previous Thread
Next Thread
Thread Tools | |
Posting Rules | |
