Gilson snow blower engine swap with harbor freight 6.5hp engine - Snowblower Forum : Snow Blower Forums
post #1 of 7 Old 01-03-2015, 05:38 AM Thread Starter
I've got a old Montgomery ward blower made by Gilson for free. The original 5hp Briggs & stratton engine 130202 was tired(lack of compression). I am thinking about swapping the old engine with the Harbor Freight 6.5hp engine.
I am having a problem with mounting the traction idler pulley onto the new engine. The original idler pulley bracket was elbow-shaped and mounted on engine with a 1/2in bolt.The bracket was linked to blower frame with a spring so that the tension of the idler was self adjusting.
The Harbor Freight engine does not have a matching mounting hole.
What option do I have to mount the idler pulley on the new engine?
I have attached a picture of the old engine set up and a picture of the new engine.
ID:	33993   Click image for larger version
tbe55 is offline
post #2 of 7 Old 01-03-2015, 05:53 AM
Thanks (Received): 367
Likes (Received): 1303
you could rebuild that old BRIGGS engine also. and save yourself the head ache of trying to match up that stuff. ALOHA from the refrozen TUNDRA.
post #3 of 7 Old 01-03-2015, 06:00 AM Thread Starter
I thought rebuilding the engine will be more work
tbe55 is offline
post #4 of 7 Old 01-03-2015, 06:10 AM
not really.
post #5 of 7 Old 01-03-2015, 08:55 AM
Spectrum's Avatar
Thanks (Received): 40
Likes (Received): 149
I can’t seem to find the pictures but I have seen a stanchion built to support that pivot point. It was an angle iron upright anchored to the chassis You could come off the 2 top accessory holes on that crank case cover with an auxiliary plate or strap made to span over to that location to provide the mounting point. That ” bolt size was based on the socket that was already part of the engine casting. With some adapting I’m sure a 3/8” bolt would be adequate.
As for rebuilding what is ailing about the engine? Unless the cylinder walls have been damaged the need for a tear down ring job is usually gross overkill. Refitting valves, refreshing the ignition as conventional or solid state or carburetor service are usually root cause. In reality I say this more for general information. In your case the 5HP engine leaves that unit very underpowered. If I were to go through the effort I'd be looking for an 8HP engine.
Pete
Spectrum is offline
post #6 of 7 Old 01-03-2015, 09:43 AM
94EG8's Avatar
Thanks (Received): 48
Just as an FYI the piston and rings used in those old 5hp flatheads is the same as the ones used in 3 and 3.5hp B&S flatheads used on lawnmowers that you see people throw out all the time.
94EG8 is offline
post #7 of 7 Old 01-03-2015, 04:40 PM
Thanks (Given): 66
Thanks (Received): 19
Likes (Given): 130
Likes (Received): 27
tbe55 -- I may be wrong, but I can't recall seeing a HF engine that was that balnd in the front section....meaning the usually they have numerous pre-threaded holes in the front area. I know the 301 cc HF engine I just used to repower a Craftsman blower surely did...
gsnod is offline
