snowflite only works at higher speed - Snowblower Forum : Snow Blower Forums
post #1 of 10 Old 01-09-2015, 07:00 PM Thread Starter
I picked this unit up used. It ran, but had little forward power. It only ran a bit at the higher speed settings. I assumed the rubber drive wheel needed to be replaced. With the new wheel it has plenty of drive power, but only at reverse and the higher settings. There is no power at the lower settings.
I did clean off the disk that drives the rubber wheel, but I was wondering if I should lightly sand it to score it a bit.
Failing that, I was wondering if there was something else that I was missing.....
Any suggestions would be greatly appreciated
msloan is offline
post #2 of 10 Old 01-09-2015, 11:25 PM
db9938's Avatar
Likes (Received): 292
Have you adjusted your drive belt?
post #3 of 10 Old 01-10-2015, 07:29 AM Thread Starter
I have replaced the belts, but I have not, as yet, found any way to adjust the tension.....
msloan is offline
post #4 of 10 Old 01-10-2015, 03:17 PM
db9938's Avatar
Do you have a model number? Maybe with that we can find an exploded diagram, and point you in the right direction.
post #5 of 10 Old 01-11-2015, 02:17 PM Thread Starter
Thanks for asking. It is a MTD 544 Snowflite, model 318-600-500.....
msloan is offline
post #6 of 10 Old 01-11-2015, 10:35 PM
db9938's Avatar
Well, I wish I had better news about finding something that would help, but I have not.
Is there a chance at taking and posting some pics of the machine?
post #7 of 10 Old 01-11-2015, 10:46 PM Thread Starter
I hope to have a better look at the machine tomorrow, weather permitting. What specifically would you like pics of?
msloan is offline
post #8 of 10 Old 01-12-2015, 01:09 AM
db9938's Avatar
The right side of the tractor, right before the bucket. And the the handle controls if you can.
post #9 of 10 Old 01-13-2015, 11:11 PM
Gprez2006's Avatar
I have a 1984 Montgomery Ward/MTD snowblower that is the same as your Snowflite. Here is a pic of a page from the owners manual that deals with adjustment of the drive clutch rod.
Hope it helps.
1984 Montgomery Ward/MTD 5hp Briggs re-powered with a 212cc 6.5 hp Predator engine.
Gprez2006 is offline
post #10 of 10 Old 01-13-2015, 11:22 PM
Gprez2006's Avatar
<a href="http://s1284.photobucket.com/user/Gerald_Thomas/media/imagejpg1_zpsc1079114.jpg.html" target="_blank"><img src="http://i1284.photobucket.com/albums/a576/Gerald_Thomas/imagejpg1_zpsc1079114.jpg" border="0" alt=" photo imagejpg1_zpsc1079114.jpg"/></a>
